Old September 27, 2011, 09:13 AM
Thankyou guys, more coming very soon. i have just sealed a deal with EK and ASUS so this baby is going ROG watercooled
And much much more work to come, currently fitting the Sentry lxe in to my top panel
Old September 27, 2011, 10:10 AM
Keywork's Avatar
That NZXT PSU sure is perttyyyy. Looking forward to the end product!
Old September 27, 2011, 10:29 AM
Wow!
I cant wait to see the final product.
Old September 28, 2011, 12:57 PM
@ Keywork, I will be painting the PSU black and maybe covering in Carbon Film (Di-NOC) and accenting it with 1.2mm EL wire
@ Insomnia9669 much more to come
@ALL......
I am happy to announce 3 Further sponsors for my build
ASUS, crosshair V formula
EK, complete WC system (board and core)
ELwirecraft, alectroluminestent wire and panels (tron stuff lol)
Propper rundown on parts coming soon
Old October 8, 2011, 05:06 AM
Finaly got time for an update, here goes....
Time I started work modifying the NZXT Sentry LXE to modify it for the front of my case top
Cutting is going to take a while, love or hate NZXT most will say there products are sturdy and the LXE is no different, the front bezel is 5mm anodized brushed alu
let the cutting begin, for this i will be using the trusty Dremel with MNPCtech.com reinforced cutting discs but even with good discs this will take a while... i will spare you a million shots of cutting
2 hours.... YES 2 HOURS later......
ok now I have got the bottom off time to make it fit the shape of the case top...... time for this to go on a diet
ok now its the correct size
On to the next problem, this is black anodized and brushed so i have 2 problems... i need bare metal..... AND the brushing is in the wrong orientation
SANDING TIME
Flat sanding using 400grit wet and dry paper, very similar principal to lapping a CPU, but with the larger surface area this will take longer
After 30mins
After an hour
After 3 hours and 30 seconds under a mouse sander to rough the surface
Next up... rebrushing to match the direction of the metal i am using on the case, 800grit wet and dry until silky in apperance (you must sand only in one direction or your just sanding not brushing) after a uniform finish is attained its on to 180gritsand paper untill you end p with...
There fixed.... coming up in next post New supply drop
Old October 12, 2011, 01:46 PM
What's on the menu today???...... Filling... mmmmmm my favourite... *Runs ff to cry in the corner*
I hate filling but these things must me done, the first plan for the side had 2 vents on the side of the window using the old window shape as a guide, but on reflection it just looks like I missed a bit so time to bring out the filler
Spot the missing bits??
Ok here we go, first up, making plates to fill the gad befor I fill. I have cut off a lot of metal to make the window shape and i need metal of exactly the same thickness to bridge the gap in the panels.......
TADAAAAAAAA use offcuts for spare material
OH look a perfect fit.... LLLLIKE A GLOVAAAA!!!!
Time for the filler, i wont be giving a tutorial on this as most brands differ by huge amounts on the part to part ratios, this one is a 1-50 mix with a working time of 5mins, sandable in 20mins and complete cure in 2 hours
FYI... love the smell of the stuff...... from the yelling i am going to assume my wife does not
Worked with it a little to long but made sure i applied thick enough to get away with it....
Now on to the sanding....... there did you like that.. me too
After a full cure it is ready to prime but first.....
NURSE???????? BRING IN THE PATIENT!!!!!!!
It is time to operate on the NZXT HALE 90 PSU
I need to get it apart to mask off for priming
A naked PSU.... shield the children's eyes
Primed. And i found out a matter of note.... spraying in a room with zero ventilation that is only 40cubic feet is not good for you......... but it sure is fun
Old October 12, 2011, 04:39 PM
Pabz0r545's Avatar
I like what i see so far! I can't wait to see the finished product.
Old October 19, 2011, 06:00 AM
One of my fave activities today..... Chassis cutting
The NZXT Tempest Evo can accomodate a 240 this rad in the roof although you wouldnt know until you take the 140mm fans out.
So i was about to make some templates for some rad holders when as i took the 2 140mm fans out of the roof i found a set of mounting holes, now if these are for a rad im not sure but they match up to the middle set of mounting holes perfectly with 120x15mm spacing and apart from mounting i can see no reason for them to be there. The airflow is very restricted though due to the centre plate so without further ado.... LET THE CUTTING BEGIN
First up, marking out the areas to remove with extreme prejudice and a dremel....... HINT... dynamite is not accurate enough do not use.. although i doubt it would scratch this case, rugged is not the word
All marked up, now for the fun.... erm i mean "now to cut out the areas with supreme precision"
ok thats the top cut out, now for the side.. when making the side wondow i completly forgot to make sure that the fan would fit next to the drive bays..... whoops it didnt.... and so..... MORE DREMEL
By a massive stroke of luck the removed bays make a great area to install my PSU hood and new drive holders..... and now if you will excuise me i have work to do and i plan to pretend i intended to remove the bays all along......
coming up..... Cereal boxes and there many uses
  #19 (permalink)
Old November 23, 2011, 02:52 AM
Fear not Guys and Gals i have not abandoned you all, i am waiting on a ton of deliveried for supplies and several sponsors including
Enermax
ASUS
SpecialTech
Lots of updates on the way as soon as i get my shipments
  #20 (permalink)
Old November 26, 2011, 02:45 PM
Supply Drop
It is that time again and another supply drop has arrived, this time it is my much anticipated EK Watercooling
So lets see what we have on the box........
Fittings, Res, CPU waterblock, MB waterblock, Pump, and Some EK UV blue coolant
First up for a closer look, the MB waterblock for the ASUS Crosshair V formula
The Crosshair V only has space fo a small MB waterblock but it looks great non the less
I am happy to report this comes with all the fixtures you will need and the thermal pads too
Next up... CPU waterblock (Supreme LTX AMD)
Ahhhh a thing of beauty, chunky and very heavy for its size, always reasuring
This also comes with all fixing you will need, and the AMD LTX blocks do not require a dedicated backplate
Next... EK multioption res 250basic
I am mystified as to why this res is called the basic, the options are just great, whilst it lacks the 2 front facing ports of the advanced model it gains a top port ideal for filling
Inclided... 2 port caps, bolts for mounting, mounts and threaded internal tube
Fixings, not a lot needs to be said here exept they are all of great quality. In a break from the norm i will be using barbs as i like the look. Same goes for the UC blue fluid, i simply cannot resist UV blue and EK has some of the best UV dye around
Last up, from EK, the pump, as i am using a cross flow rad that will be roof mounted i wont need a hugely powerful pump to move the head of fluid so i went with the nice compact DCP 2.2
Again there is plenty supplied including 3 to 4 pin converter and mounting brackets
And my radiator the Hardwarelabs GT Gen2, this is a cross flow with ports on either end rather then the traditional PC watercooling of a twin layer return flow, and perfect for my requirements, great flowrate and perfect for clearing board architecture that may get in the way of a more conventional rad
A MASSIVE THANKS TO EK FOR TAKING A CHANCE ON SPONSORING THE NEW KID ON THE BLOCK
Project: i7³ Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 06:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
