-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   WIP Heat My House !! (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/45555-heat-my-house.html)
BrainEater August 10, 2011 03:02 PM
Heat My House !!
As much as this belongs in the folding section , it belongs here.
I've upgraded and moved a portion of my folding rigs out into the garage with the purpose of heating it . It's a north facing garage and is always cold , especially in the winter.
This will be a good test of the components , for thermal shock......there might be 40 degree temperature shift in the middle of winter , twice a day ;
http://braineater.kicks-ass.tv/miscshite/heaters1.jpg
Thats 2500 BTU's of heat.
:haha:
So here's a couple questions :
Has anybody here ever used a pci-e 'riser' ?
I know AGP risers will do a 4 inch space.....I need to separate a video card from the mobo....
Whats the smallest mobo that will run an NV580 ? Will one of the 'nano-ITX' boards run one of those ?
Thanks for any input , I have a plan.
:thumb:
3.0charlie August 10, 2011 04:20 PM
I believe a few have tried using pci-e risers, sswilson amongst others. Don't know about the length, found a 2.5" here: http://www.plinkusa.net/webR1PCI-E1-1R.htm
As for your board question, any size of a board can work with a NV580 - as long as it has a 16x pci-e slot. Cases and PSUs though, that's another story...
Toyoracer August 10, 2011 04:28 PM
The only one I have seen is Attila's Cor Leonis link
Here are the nano boards
3.0charlie August 10, 2011 04:46 PM
This? Scratch Build Cor Leonis - bit-tech.net Forums Nice.
Supergrover August 10, 2011 04:51 PM
Originally Posted by 3.0charlie (Post 540113)
That is pretty sweet.
Toyoracer August 10, 2011 05:13 PM
Thanks that's the one, been following from the start.
BrainEater my only concern in the very cold, might condensation still form from the extreme temp change coming into the computer ?
CroSsFiRe2009 August 10, 2011 07:01 PM
Yep, I've used pci-e risers with my 470's and 5830s. One's I've been using are 12cm long.
Picked them up from here $9 for 2 Lots PCI-E PCI-Express 16x Riser Card Extender Cable 1U 2U
There's tons of bitcoin miners who use them too https://bitcointalk.org/index.php?topic=7216.740
If a 6990 or 5970 works, I'm pretty sure a 580 wouldn't be a problem. You might run into issues if you have too many gpu's running off one mobo though so if you're looking at running say 6 580's off a board, you might need to split the pcie 12v line to a molex plug.
https://cablesaurus.com/index.php?ma...30d594770c430e
Eldonko August 10, 2011 07:18 PM
heheh awesome. My basement is always warm in the winter :D
Sagath August 10, 2011 07:25 PM
Condensation shouldnt be a concern assuming well vented cases. I would probably leave the side panels off and a fan pointed at them and it shouldnt be an issue.
Does your garage really go from -40 to 0c throughout the day? Steel roof with no insulation? :shok:
PerryC August 10, 2011 07:41 PM
More likely an insulated, but unheated garage. If its anything like my garage ambient in the winter hovers around 12C or so. Open the door to let a vehicle in or out and that temperature drops in a hurry. May not be a full 30 or 40 degree drop, but sure as hell feels like it, Since there is no real source of heat in the garage it takes a while for it to warm up.
