Old July 16, 2011, 11:35 AM
Default Laser cutting question
Does anyone have experience with a Canadian shop that does laser cutting?
I've got 2 radgrills that I need to have laser cut and would really rather avoid cross-border shipping.
Alternatively, does anyone have experience with a shop in the states that charges reasonable rates for shipping?
It would be an added bonus for me if the same shop could also countersink the mounting holes and paint the grills too.
Thanks in advance!
(FWIW, I've got the layouts done in .dxf (just the layouts) and .pdf (with dimensions) files)
Old July 16, 2011, 02:35 PM
supaflyx3's Avatar
PC Case Mods Store & Professional Case Modding
i suggest them, they're american but are good :)
Old July 16, 2011, 02:58 PM
Do you happen to know if they ship via UPS or USPS to Canada?
Old July 16, 2011, 03:09 PM
PerryC's Avatar
mnpctech is a member of these forums...drop him a pm and ask him directly.
Old July 16, 2011, 03:25 PM
Thank you, I didn't know.
Old July 16, 2011, 10:54 PM
supaflyx3's Avatar
If you talk to them directly you can ask for either or.
Old July 16, 2011, 11:51 PM
EmptyMellon's Avatar
Arrow Laser Equations or alternate
If you are in the Calgary area then you can try Laser Equiations, I do not know how they are for shipping for out of Calgary jobs. Their contact info should be on their home page: Laser Equation - Industrial Cutting Solutions
Edit: Alternatly, if you would care to have them machined, I can see if the company I contract to can provide you with a quote (Red Deer area).
Old July 17, 2011, 06:48 AM
krazyups's Avatar
I would imagine that most metal working shops have some laser cutting equipment. If you're up around the Markham area, my company does quite a bit of business with Stentech (laser cut stencils for solder paste application onto PCB's). I know that there are a few shops around the windsor area that do this as well, but the names escape me for the moment.
Old July 17, 2011, 06:54 AM
BrainEater's Avatar
Laser cutting is actually pretty common....the brackets we lift buildings with are laser cut.
We get em done at JP Metals Calgary.
Now , laser cutting may not actually be what you want , depending on the material , waterjetting may be what you want.
Start looking at metal fabrication shops in your area , there is no reason to get it done in the U.S. , there's metal shops all across Canada that can do it.
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
Old July 17, 2011, 09:18 AM
I'm actually in the Ottawa area, and the suggestion to check with local shops is a good one. I keep forgetting (and getting reminded) that not every business has an online presence.
Xai laser or the Ikari laser shayan288 Peripherals 17 October 31, 2011 09:16 PM
z550 cutting in and out? Cadence Audio 36 March 17, 2009 08:39 PM
Internet keeps cutting. Kayen Networking 10 October 20, 2008 08:14 PM
Laser Cutting JD Cases 10 September 16, 2008 08:01 AM
Cutting tubing elninio Water Cooling 11 June 10, 2008 04:14 PM
