  #41 (permalink)
Old May 7, 2008, 07:09 PM
MpG's Avatar
MpG MpG is offline
Eh, dunno. Aside from the additives, I only used distilled water in this system. The chipset loop with Hydrx is still looking good (also Tygon), and I didn't have any clouding in my old Koolance system. I guess time will tell.
  #42 (permalink)
Old May 7, 2008, 07:13 PM
3.0charlie's Avatar
I'm sorry - I meant to write that I used to have a loop with all 3 tube manufacturers at the same time, and all 3 had the cloudiness - but not the MicroRes. Go figure.
I remember too that my first loop with my Koolance Exos2 did not have any cloudiness.... different liquid? I used the Koolance stuff back then.
Hydro-Quebec is salivating...
  #43 (permalink)
Old May 7, 2008, 07:49 PM
MpG's Avatar
MpG MpG is offline
The Koolance stuff's got some kind of Glycol in it, which is a whole different animal than water. But since I don't know what specifically is making the tubing cloudy in the first place, I'm not sure how/if that would make a difference.
  #44 (permalink)
Old May 7, 2008, 08:23 PM
biff's Avatar
I used to run a DI w/15% glycol mix and never recall cloudy tubing, could be the corrosion resistance of the added glycol. It appears the tin plating, or whatever it is, on my fancy barbs are a little discoloured too, could be some sort of galvanic reaction happening. Next coolant change I think I might try 5% G12 and see what turns up.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
  #45 (permalink)
Old May 7, 2008, 08:47 PM
MpG's Avatar
MpG MpG is offline
You know, that might just be it. Looking at the ingredients on my bottle of Hyrdx, the stuff's got Glycol in it too. Hmm...
I've honestly never read anything suggesting this before. I know that the thermal characteristics of glycols are noticeably worse than straight water, which is why it isn't normally used in systems that don't drop below freezing/have mized metals in them. Hope I remember to check my tubes when I pull them this summer. Could be interesting.
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
Project Darkside BALISTX Case Mods, Worklog & Gallery 44 October 14, 2007 06:44 PM
BALISTX'S 939 Project BALISTX Case Mods, Worklog & Gallery 55 September 26, 2007 04:23 AM
Antec P190: I have fallen and can't get up... 3.0charlie Cases 18 May 28, 2007 05:12 PM
Antec reveal the P190 and itís a monster!: Hexus Babrbarossa Reviews & Articles from the Web 30 March 18, 2007 09:47 AM
