Ok, I've started down the path. I will be acquiring the parts over the next little while as finances permit, but I've made the initial order for some components.
I'll update this with planning and pics once I get the components and the loop starts to take place.
I am going for the following loop
Res>Pump>Rad>CPU>GPU>NB>Res
The GPU is still not decided, although I think I'm going to have to stick with my current 8800 GTX for cash concerns, since this project will eat up most of my budget for a new card...
Oh well, c'est la vie.
Still not sure whether to get a full coverage GPU block or go for a regular GPU block and heatsinks (which also might be re-usable when I eventually update to a new card)
The jury is still out on the 3870x2 and I'm not sure it's worth ditching the 8800 GTX for that, so I think I'll wait for the next generation of cards.
In the past couple of days I've ordered the following:
D-Tek Fuzion CPU block w/Pro Mount
Thermochill Pa 120.2
Ek Water Blocks EK-NB S-MAX Plexi Top Motherboard Chipset Water Block
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Thermochill 1/2IN Chrome Plated Barb Fitting G3/8 Threads *Single Barb* x2
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
Swiftech MCB-120 Radbox Revision 2 Black
Thermalright HR-09S Type 2 Mosfet Heatpipe Cooler
Thermalright HR-09U Type 2 Mosfet Heatpipe Cooler
