  #71 (permalink)
Old March 21, 2008, 10:05 AM
zlojack's Avatar
The BIOS support from Asus on this has been pretty slow....
I've been using 1004 for the last little while and it's been so-so. I really haven't pushed it with my QX9650 since I was going to start the water build and did so 4 days after getting the quad.
The 0907 bios was also good. I used that with my E8400 no problem, but the tRFC was too limited for overclocking 2GB modules. I have seen issues with that RAM in the huge thread over at XS. XtremeSystems Forums - View Single Post - Asus Maximus Formula *Part 2* *Help / Overclocking / Guide*
I guess it depends which revision the sticks are.
Anyway, here's some progress from last night (up til 4AM )
  #72 (permalink)
Old March 21, 2008, 10:11 AM
Prof. Dr. Silver's Avatar
That is one sweet looking rig already! Can't wait to see the final result!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
  #73 (permalink)
Old March 21, 2008, 10:13 AM
sswilson's Avatar
Dual 655s???? Heh.... you could fill up a swimming pool in half an hour....... :)
  #74 (permalink)
Old March 21, 2008, 10:15 AM
zlojack's Avatar
So I guess flow won't be a problem on my loops!
I have a slight problem...
I can't find the damn 4-pin ATX cable for my PSU! I know my mobo actually has an 8-pin slot with a cap on the other 4 holes. Could I use one of the 8-pin connectors? Or will it be fry-ville?
  #75 (permalink)
Old March 21, 2008, 10:18 AM
sswilson's Avatar
What PSU? You can't find it? Is is modular?
  #76 (permalink)
Old March 21, 2008, 10:23 AM
zlojack's Avatar
Yes it's modular. It's the Silverstone Zeus I bought from SKYMTL.
I pm'd him to see if he overlooked that cable when he packaged it up for me.
I looked everywhere for the damn cable. I never really unwrapped the bundle of cables that came with the PSU until today (since it would have been a mess) but there were some loose ones in the box, so maybe I put it somewhere to keep it "safe", but now I can't find it.
I'm wondering if one of the 8-pin PCIE cables would work in its place.
  #77 (permalink)
Old March 21, 2008, 10:25 AM
sswilson's Avatar
Absolutely not!!!!!!!!!
I don't have the specs in front of me, but I'm almost positive the pin-outs are different!!!!!
  #78 (permalink)
Old March 21, 2008, 10:27 AM
zlojack's Avatar
Thought so....
Crap!
Well, I'll continue with the other stuff for now and hopefully the cable will appear. Otherwise I'll have to track one down....
  #79 (permalink)
Old March 21, 2008, 10:32 AM
I was always told to use the 8-pin ATX cable for a better, stable, more sufficient supply of power. And I never had any issues!
  #80 (permalink)
Old March 21, 2008, 10:33 AM
sswilson's Avatar
Power supplies and cooling devices from PC Power and Cooling, Inc.
Looks like the 12V power is on the opposite side of the connector, and I don't know about the +2 part of the plug.
Upgrade path possibilities ... Synth CPU's and Motherboards 5 March 17, 2008 10:25 AM
Tales from the DARK side sswilson CPU's and Motherboards 19 June 5, 2007 04:35 PM
VR-Zone posts side-by-side comparison of 8800s and r600s Babrbarossa Video Cards 4 May 2, 2007 08:50 AM
DX10 / DX9 side-by-side screenies for CONAN Babrbarossa Reviews & Articles from the Web 4 May 1, 2007 04:00 AM
Vista Upgrade Path Gav O/S's, Drivers & General Software 14 March 30, 2007 01:43 AM
