Ok...some progress!
Finally got the motherboard done up and the waterblocks put on the mobo and the GPUs. Hopefully tonight I can finish the install and start the leak test... *crosses fingers*
The Maximus Formula has a problem: once you've run it and the thermal adhesive cures, it's a real pain to get the stock heatsink array off. There are two ways to do this: heat or cold.
I opted for cold and put the motherboard in the freezer overnight (couldn't find freeze spray anywhere!) on Monday and Tuesday morning the heatsink array popped off like nothing. Cold is definitely the way to go for this.
I mounted the Fuzion with the Pro Mount kit but instead of the Pro Mount backplate, I used the backplate from my Thermalright Ultra 120 Extreme since it has posts that go through the holes in the mobo, making it easier to reseat the block without having to dismount the motherboard in the future.
The EK NB went on no problem once I drilled out the backplate (bye bye warranty, I hope my board works when I power back on!!!)
The SB was a bit of an issue as the Enzotech block I bought had to be modded slightly and still went on crooked... I had to drill an extra hole closer to the body of the block to get the pushpin to go all the way through....it's not pretty, but it's on there nicely, and can be removed should I decide to do so in the future. I also had to bend the pin in the top corner to get the pushpin to fit...
Thermalright HR-09's went on the mosfets and now tonight I should be able to put the loop together!
Here are some pics.
Waiting to be violated
A night in the freezer and *POP*
Shiny Fuzion
Fuzion with Pro Mount and TRUE backplate (check the quad nozzle!)
CPU & NB partners in crime!
Here's my crooked SB cooler...still makes full contact!
All together
Hate to see her go
EK work of art!
Partners in crime!
This guy's up next, God of Thunder, Zeus!
