  #51 (permalink)
Old March 2, 2008, 01:20 PM
zlojack's Avatar
Small update. After 3 coats of grey primer, here's the first coat of black.
I'm going to use matte black as the "black primer" then sand and finish with glossy black and a clear coat for a nice deep gloss look.
Hopefully it works. I wasn't too impressed with the black paint today... seemed to go on sort of "bumpy". Hopefully I can sand it into submission. I guess that's the danger of painting in the cold.
Anyway...here are the pics of today's progress:
[SIZE=3]
  #52 (permalink)
Old March 2, 2008, 02:18 PM
llama_egg's Avatar
Lookin' pretty good so far. Can't way to see how the paint looks when finished!
  #53 (permalink)
Old March 9, 2008, 12:18 PM
zlojack's Avatar
Got some ok painting weather today...so here's the last coat of the gloss black.
There are two spots where the damn paint dripped... I'm going to see if sanding and polishing gets it out, or I might have to re-coat the side panels.
Anyway... after this comes clear coating and then (finally!) the build!
[SIZE=3]
  #54 (permalink)
Old March 12, 2008, 01:00 PM
zlojack's Avatar
Ok... I got a box from NCIX today with "loop 2" and some other odds and ends.
Also got my tax return!
I just ordered a QX9650... I feel sort of strange and giddy!
Second 3870 X2 on the way as well
If all goes well, I could be building this by next week!
In the mean time, I still have some work to do on the paint finishing. I put a couple of coats of clear coat on, but it's not looking too great. I am going to sand it smooth and do another coat.
What grit should I use for this step?
[SIZE=3]
  #55 (permalink)
Old March 12, 2008, 02:30 PM
Cptn Vortex's Avatar
Ouuuuuu nice!!!
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
  #56 (permalink)
Old March 16, 2008, 06:35 PM
zlojack's Avatar
Ok... so made some good progress today. Cleaned the loop components and flushed the rads. Installing all the fittings now with teflon tape.
Once I get everything set up, I'll get some pics of all the components before they go together into the loop.
[SIZE=3]
  #57 (permalink)
Old March 16, 2008, 07:40 PM
zlojack's Avatar
So..here's my next challenge:
I've found I won't be able to fit a shroud on the internal rad in the front drive bays so now I need to decide which loop to hook up to the exterior rad (dual shroud push/pull) and which loop to hook up to the internal rad (push/pull no shrouds)
I figure, the CPU and NB will be hot, but the GPUs run much hotter under load...
I know the shroud usually only makes a couple degrees difference either way, but should that go to the CPU/NB or the GPU loop?
[SIZE=3]
  #58 (permalink)
Old March 17, 2008, 04:35 AM
sswilson's Avatar
I would go with the CPU/NB.
GPUs might run hotter, but there's normally more headroom on CPUs which is only limited by heat.
You'll also get a bit of a cooling boost by being outside of the case due to lower ambient temps.
  #59 (permalink)
Old March 17, 2008, 01:42 PM
zlojack's Avatar
So GPUs on internal, shroudless and CPU/NB on external?
I think it'll work... I'm getting close to the point of actually mounting stuff (hopefully tonight). I need to buy some screws since my Thermochill is causing some mounting headaches... hopefully Crappy Tire will sort that and then I should have some stuff mounted in the case tonight and maybe even have the loop sussed out by then.
That's after hitting the pub for a St. Paddy's day pint of course
I charged up the camera last night, so hopefully pics to come this evening!
[SIZE=3]
  #60 (permalink)
Old March 17, 2008, 05:08 PM
Babrbarossa's Avatar
Just be very careful not to poke holes in the fins with extra long screws- that would be tragic ;-) Sometimes washers can help for slight adjustments to length. I've had good luck just cutting long bolts off with a dremmel- doesn't mess up the threading like I thought it would- just screw a nut onto them after cutting the ends off to straighten the threading if it looks a little ragged on the end. Works best when the metal is still warm.
psst, wanna see my binder?
Upgrade path possibilities ... Synth CPU's and Motherboards 5 March 17, 2008 10:25 AM
Tales from the DARK side sswilson CPU's and Motherboards 19 June 5, 2007 04:35 PM
VR-Zone posts side-by-side comparison of 8800s and r600s Babrbarossa Video Cards 4 May 2, 2007 08:50 AM
DX10 / DX9 side-by-side screenies for CONAN Babrbarossa Reviews & Articles from the Web 4 May 1, 2007 04:00 AM
Vista Upgrade Path Gav O/S's, Drivers & General Software 14 March 30, 2007 01:43 AM
