Originally Posted by 3.0charlie One thing I will try one day is a dual loop with a single reservoir - like a 5.25 bay res, with dual inlets and a single exhaust with a Y. |
That would be cool, but I am going with two different colours of coolant, so I'd like to have two different reservoirs.
Now comes the fun part... waiting for the primer to dry and sanding
Then cleaning, priming again, waiting and sanding.
I figure two more coats of primer nicely sanded. Then 3 coats of paint nicely sanded.
One thing I haven't been able to find is spraycans of clearcoat. At least at Canadian Tire.
I might have to try Home Depot...
Also, for edging the holes I cut in the mobo tray, I was thinking of using 1/8" tubing, but it looks like crap. What do you guys use? I've seen guys with nice black rubber edging material.
