-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   New case! -HAFX + a whole ton of red (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/42501-new-case-hafx-whole-ton-red.html)
Brian@NCIX April 13, 2011 11:59 PM
Hey guys, just upgraded from my 912 to a HafX!
Also got :
Coolit Eco 240MM w/ 4x SS Air Pen
3x CM 200MM Megaflow
1x Xel 140MM RED LED Fan
My current specs as of now:
i7 970 @ 4.55ghz
12GB OCZ-Obsidian DDR3-1600 @ 1699
Sabertooth X58
2x 6950 flashed to 6970's @ 900/1450
Soundblaster Titanium HD XFI
Intel Gigabit LAN adaptor
Corsair F90
WD 2TB Green x2
WD 1TB Black
Seagate 1TB
Corsair TX850 (need..AX1200 :()
I got rid of a lot of my harddrives, seeing as how I really dont use a lot of space anymore.
ANYWAYS good stuff ----V
http://a6.sphotos.ak.fbcdn.net/hphot..._3395647_n.jpg
How it looked before xfering everything over.
http://a4.sphotos.ak.fbcdn.net/hphot..._4233730_n.jpg
The C240 with 4 SS Air Pens! I chose these fans because they have superior directional flow, instead of HOLYJESUSWHEREISTHISAIRGOING, IDONTKNOW, ANYWHEREBUTTHERADIATOR!
http://a6.sphotos.ak.fbcdn.net/hphot..._5393728_n.jpg
2 big ass fans mounted, with the radiator on the bottom (yes you can run both if you wish)
http://a8.sphotos.ak.fbcdn.net/hphot..._7709753_n.jpg
Test fitting everything...had to move the videocard back to the 2nd PCI-E, my Xfire bridge wasnt long enough :(
http://a4.sphotos.ak.fbcdn.net/hphot...0_249008_n.jpg
http://a4.sphotos.ak.fbcdn.net/hphot..._7918768_n.jpg
http://a2.sphotos.ak.fbcdn.net/hphot..._4569429_n.jpg
In the Pic : Asus 23" (i think its VE23R?...), Samsung 2343, Corsair HS1 Headset, Corsair SP2500, Steelseries 6Gv2, Steelseries Xai, Steelseries 4H, xbox360 hooked up to the acer monitor :)
Enjoy!
Rison April 14, 2011 04:38 AM
Really? direction of airflow means 0 in a radiator. This is assuming you, you know.. have them all going in the same direction of course. Unless of course you mount the fans 4 inches away from the rad, which no one does.
It's screwed directly on it.. the fans you're looking for need good static pressure, not directional air flow.
I would however, like to test those fans versus some other manufacturers high static offerings. Hmm.. I might just do that.
Brian@NCIX April 14, 2011 07:56 AM
the gentle typhoons were out...so were the ultra kaze's, the CM R4's had terrible static pressure, these were the next best thing without having my computer sound like a windstorm! i'll be replacing them when my desired fans come in :)
Quirck April 14, 2011 06:21 PM
Nice!
Keywork April 14, 2011 07:08 PM
What kind of temps are you getting with that C240? Decent build though!
Reyzac April 15, 2011 04:04 AM
How are you liking those Corsair speakers?
Brian@NCIX April 15, 2011 10:20 PM
On my old NH-U12P SE2, I was getting an average 85c on all 6 cores, now I average about 70-72c. I have the thing 4.66ghz @ 1.3vcore
The corsair speakers are nice, theyre great for their size, but it lacks a quite a bit of treble, mucho amounts of mid and bass though :P
Brian@NCIX April 17, 2011 08:19 PM
http://a7.sphotos.ak.fbcdn.net/hphot..._4959639_n.jpg
/trollface
http://a1.sphotos.ak.fbcdn.net/hphot..._5970944_n.jpg
http://a8.sphotos.ak.fbcdn.net/hphot..._1045646_n.jpg
it is. huge.
