Old February 25, 2011, 02:56 PM
Default Using 2 different PSU's on one system
is it possible to hook up 1 system to 2 different PSU's for example put half the fans and a gpu on one psu and the other half and another GPU on the other? or would power management get messed up?
Would definately be more cost efficient than picking up a single 1000w+ psu.
Old February 25, 2011, 03:00 PM
sswilson's Avatar
You can, but unless you've got a way of telling the second PSU to start up (there are ways to do it) you'll need to jumper the 24 pin and turn it on manually before turning on the system and off after you shut the system down.
Old February 25, 2011, 03:01 PM
howpet's Avatar
Someone's gonna ask: What are you using that you think you need a 1000w? I guess I just did
Old February 25, 2011, 03:21 PM
SugarJ's Avatar
You need one of these adapters: Dual PSU 24-Pin Adapter Cable Products Model: ULT40011 [DualPSUAdapter] : Performance-PCs.com, ... sleeve it and they will come
It autostarts the 2nd PSU when the 1st one starts. I have run dual PSU's this way.
Old February 25, 2011, 03:24 PM
Well nothing right now I'm just curious at this point because I have no money but maybe down the road I'd like to build my computer into a cabnet mounted on a wall beside 3 large T.Vs also mounted on the wall. in a massive 50inch eyefinity or surround setup with 3 of the best graphics cards I can buy lol
Hey it can't hurt to dream.
P.S I'll be a geologist so hopefully unless i have a family I can afford it considering the average geologist makes just short of 6 figures and ty for the info only 1 more year to go lol
Old February 25, 2011, 03:26 PM
SugarJ's Avatar
When the time comes, an extra $100-150 for a proper PSU will be a drop in the bucket compared to the rest of your triple GPU setup.
Old February 25, 2011, 03:31 PM
I know but if I have 2 PSU's in different compartments I will generate less heat in my cabinet.
Old February 25, 2011, 03:54 PM
Or you could just buy a better, more efficient unit. Some 80+ Gold units barely kick out any heat until you put a huge load on them. Platinum units are around the corner too.
OCZ High-Performance PSU Meets the Demands of Gamers and System Builders with Low-Profile Cabling mikellini Press Releases & Tech News 29 June 10, 2010 06:40 AM
AMD System Build, Confused in PSU and LCD! Sprengkopf New Builds 15 July 14, 2009 12:44 PM
Changed PSU now system won't boot? Sniper Troubleshooting 3 May 17, 2008 09:54 AM
New system, will included psu work quick90 Power Supplies 5 February 17, 2008 01:33 PM
need PSU suggestions, current PSU isnt cutting it Rains Power Supplies 13 December 11, 2007 08:53 AM
