<~----> Completed Prolab's "Blacklab" WC project - Hardware Canucks
Old January 27, 2011, 10:23 AM
Prolab's Avatar
Default Prolab's "Blacklab" WC project
Guys/Gals,
Finally, im ready to WC my rig. Started more than a year ago as a budget video encoder + light gaming.
Then, throughout the last 6 months or so - slowly started making some changes (since, i cant really leave anything alone).
I know. Its looks very puny inside the HAF X. Stayed with the case for a few weeks or so, then changed my mind. Again.
So bought a 800D with WC in mind...
So i started collecting WC parts. Then Xmas and Boxing Days sales came around. Damn, my wallet is hurting but a bigger step into a better rig...
Then the HWC get together came up. Talked to a few guys and learn more about WC, the what ifs and not. Ive gotta say, im glad i came out that night. Learned some things and made a few acquintances.
Then the 6950 hack came out and decided, to pull the trigger and sold my 4890. Then, bought a few more WC parts...
And the last few weeks, bought more parts from Gary and Daz. Thanks guys for an awesome service and fast shipping.
Still waiting for the 6990 review, so for now, im just WC the CPU. But will WC the GPU if i decide to keep the 6950 or sell and move up to the 6990. Now, im just waiting for NCIX to deliver my tubing, fans and ill be posting and updates for the Blacklab.
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, i7 3930k, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Rampage IV Extreme, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (2) 3 TB Toshiba Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (5) 2 TB WD Green, (1) 2 TB Seagate HD, (1) TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Old February 4, 2011, 01:44 PM
Prolab's Avatar
Well, finally got my sleeves from MDPC-X. And started practicing on sleeving.
I found an 3-pin ext for my xigmatek fans but i couldnt for the life of me take out the wires after i use mdpc tool to press the tab in. So i went to look at my 655 and decided to sleeve it. I cut the sleeve to about the same length from the tip of the 655 to the solder points of the pins. But i messed up heating the shrink tube and the sleeve shrunk as well.
So this is what it looked like:
I need more practice .
BTW, how do you get rid of this tab right above the wires? Ive tried prying it off with a really small screwdriver and my teeth and its a no go .
More updates to come. Still deciding what wires i want to sleeve and color combination. As well, im still waiting on some sleeves from MDPC.
Gaming Rig:
Server Rig
Old February 5, 2011, 08:00 PM
Prolab's Avatar
Okay, another update...
Taking it fan apart...
I tried sleeving my 2 intake fans. First one was okay:
But i think the second one was better:
Here's the 2 fans already assembled and sleeved:
Unto the rads and rad fan. Here's one of the fans with the rubber isolator/vibration kit:
Then starting to assemble it. Then i notice, i cant screw the middle fan. Turns out, the vibration kit are a bit too thick and it offsets the fan from the ran mounting hole.
So i had to install the vibration kit on the 2 most outer fans. Then left the middle fan as it is. Here they are assembled.
Starting to take the rig apart.
Dont have a masking tape so had to use duct tape to mark where to drill:
Now, with the tripple rad on top:
Another look from the front:
Another view:
Had to move the BR player and SSD to the lower slots:
Now with the block, fittings and pump:
Tubing now in place:
The pump temporarily in its place:
One more look before leak testing:
And another:
So, double checked my fittings, tubing and location of the pump and block. Made sure their all tight and fit. Start pouring water, and my CPU block starting to leak!
Turns out, i screwed up putting the mounting plate and o-ring in place. And i cut the o-ring in half, SOB .
So i had to stop everything, cleaned off the excess water and ordered from EK 5 spare o-ring. So the rig is on hold till i get it. Hopefully by next week .
Gaming Rig:
Server Rig
Old February 5, 2011, 10:05 PM
ZZLEE's Avatar
Nice build log :) :)
Try Home hardware and ask fore a O ring or faucet kit might do the trick temporarly till you get the part.
Or hit up a plummer friend if you have one.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 6, 2011, 04:10 PM
Prolab's Avatar
Oh, thanks for the hint. I can find this at home depot or rona can i and Its a universal o-ring yes?
Gaming Rig:
Server Rig
Old February 6, 2011, 04:53 PM
ZZLEE's Avatar
O rings vary some bring one with you to compare in the store. Get as close as you can to the same size.
When you install it make sure you have extra thread space just in case itis not.
I would still order some propper ones and keed a few on hand fore feuter need.
Old February 12, 2011, 04:27 PM
Prolab's Avatar
Okay, so finally after a week of waiting parts, re-installing the o-ring a few times and little blunder here and there, she's finally completed.
Leak testing after 2nd installation of o-ring:
After 3rd...
And testing all the fans after resleeving them:
Here she is after leak testing and checking everything out (i apologize, my camera is from 2005. Horrible CMOS).
Gaming Rig:
Server Rig
Old February 12, 2011, 04:51 PM
ZZLEE's Avatar
Looking Pritty.
Hows your Temps ?
Watch North Bridge and South Bridge temp as you Overclock.
might need some fan action on them.
Old February 13, 2011, 05:39 PM
Prolab's Avatar
Thanks!
Temps are quite good. Load temp with p95 (ambient temp is 23 C), is around 45 C. It used to be around 60 C with my coolit ECO.
My mobo temp (according to HwTemp is around 28 C). Im leaving it like so for a week before i start OC it again .
Gaming Rig:
Server Rig
Completed Project "Shorty HTPC" UPDATED Aug 28/10 Varroa Case Mods, Worklog & Gallery 14 August 28, 2010 12:42 PM
WIP Project Zer0 - "Zero-Cutting" Dual Rad 800D tehpr0fess0r Case Mods, Worklog & Gallery 15 June 19, 2010 04:33 AM
Project "Veda" - Antec 1200 Build Kazushi Erukima Case Mods, Worklog & Gallery 6 June 9, 2010 07:50 PM
Project "Unus Multorum" - Rebuilding the Rebuild ChuckleBrother Case Mods, Worklog & Gallery 12 August 10, 2009 08:43 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
