Old September 7, 2010, 02:04 PM
Socrates_Johnston's Avatar
Default Lian-Li PC-8N + Spare Parts Build
I put this rig together using old parts so that my parents can have a desktop for daily usage. It was my first time purchasing a Lian-Li case, and I must say I am very impressed by the quality product I received for $99 on sale at Canada Computers... I was debating between this case and the CM 690 II but went with the Lian-Li because it has a much more elegant/clean look to it.
Lian-Li PC-8N case
Asus M2N-SLI Deluxe
AMD Athlon 64 X2 4600+
Zalman 9700 CPU Cooler
2x2gb OCZ PC2-6400 800mhz SLI-Ready RAM
BFG 7950 GT OC 256mb
WD 500gb Caviar SE16 7200rpm 16mb cache
The case came with rubber washers for the tool-less HDD mounting system to absorb vibrations. You can really tell that a lot of thought was put into designing this case. It is very very light but feels sturdy (although the front panel snaps off a little too easily for my liking).
I really like this case, but I wish the cable management was a little better (some holes to allow cables to be ran behind the mobo tray would have been nice), but the case is perfect for a simple build like this one.
It seems that 1 of the front USB ports doesn't work...I will have to look into that.
[FS] Watercooling parts + Lian Li PC-7FW (and more) m1dget Buy/Sell & Trade 6 January 10, 2010 10:50 AM
Budget HTPC from spare parts artistpavel HTPC Systems & Software 26 August 15, 2009 01:48 PM
Have spare machine, will build HTPC... Caldezar HTPC Systems & Software 10 January 27, 2009 02:27 PM
The Spare Parts PC! Chilly Case Mods, Worklog & Gallery 12 December 5, 2008 10:32 AM
FS: Bo's Spare PC Parts! bojangles Buy/Sell & Trade 20 October 10, 2008 05:26 AM
