  #51 (permalink)
Old October 11, 2010, 07:47 AM
Mnpctech's Avatar
..Wood?! ..... It's just a test so we can pre-fit the top grill frame to confirm it matches the contour of the factory version, before making real deal. The heatsink fins will be left bare aluminum while the outter frame will be painted to match the "dingy" exterior finish of the case. Otherwise it would contrast and look a bit odd...
Underside of the new top grill.. (still in progress!)
  #52 (permalink)
Old October 13, 2010, 05:18 AM
Mnpctech's Avatar
The grill will attach to the frame of the factory grill. The outter frame of the top grill will be painted to match the exterior. The heatsink fins will either be 1. left bare aluminum or 2. cleared coated with a light mixture of silver to mute the shine. I'm leaning toward the later, so the grill fits into the overall theme.
  #53 (permalink)
Old October 14, 2010, 05:47 AM
Mnpctech's Avatar
Yesterday I drilled holes into the modified factory plastic grill frame. Honeycomb Mesh was being clear coated
  #54 (permalink)
Old October 14, 2010, 06:51 AM
Fudd Rucker's Avatar
curious, is there enough room up top to mount a set of 120mm x 38mm fans? Im getting one of these cases for xmas and am shopping to fit it with my current water cooler by mounting the rad at the top. And for that matter, will there be enough room for a top mounted TFC 240?
I couldnt think of something snarky or interesting to put here this time around.
  #55 (permalink)
Old October 14, 2010, 12:57 PM
Reyzac's Avatar
I think so. I read a spec sheet that described doing just what you said. The rad will probably have to fit inside, though.
Who needs a real doctor when you got my machines and their scary needles?
I also go by Silver Blues in lots of other places.
  #56 (permalink)
Old October 16, 2010, 10:12 AM
Mnpctech's Avatar
38mm...Panaflo fans by chance? ...will check to make sure on space when I return to the shop.
fyi: Corsair hasn't released a window version of the 600T Graphite. I recently got one to install a custom window. Here is d-i-y guide I made
Install window in Corsair 600T Graphite Mid Tower. | Case Mod Blog
  #57 (permalink)
Old October 16, 2010, 01:11 PM
Either a set of panflow or deltas. I had seen in the video of how they mounted the fans on top and the radiator internally. Personally Id cut that grill out of the top to get a better seal to the rad. It would be super awesome to fit 120x38mm fans on my TFC 240 without modification.
  #58 (permalink)
Old October 17, 2010, 10:00 AM
Mnpctech's Avatar
Ok, I'll check it out tomorrow when I return the shop. The top panel for the 600T is done! Altho may paint the grill Black
  #59 (permalink)
Old October 17, 2010, 10:43 AM
Reyzac's Avatar
Yeah, paint the grill black, that would look really good.
  #60 (permalink)
Old October 18, 2010, 10:04 PM
man that some nice custom work. Wish I had the machinery and knowhow to do some of that.
Project S-RV-SE BloodRage WC MOD ProStock Case Mods, Worklog & Gallery 36 January 7, 2013 08:46 PM
Project Oroborous: The Cycle Continues - Case Mod Log Sushi Warrior Case Mods, Worklog & Gallery 60 April 15, 2012 10:58 PM
Project Reality - Battlefied 2 Mod Kommie986 Gaming 4 July 1, 2010 04:30 PM
Corsair Graphite Series 600T Kayen Cases 17 June 15, 2010 08:03 PM
Corsair Launches Graphite Series 600T Mid-Tower Computer Case SKYMTL Press Releases & Tech News 24 June 1, 2010 08:01 PM
