Old July 7, 2010, 12:53 PM
Default Where to get 1/4" wide U-channel molding?
So I decided to punch some holes tonight on the side-panel for wire-routing, and paint it black. But, I don't want to amputate myself on the sharp edges after i punch-out the holes. Does anybody know where i can get u-channel locally around Toronto?
Wanna pick them up tonight, so I don't feel like ordering online like from MNPC. But, dunno where to get 'em. Think Homey Depot has 'em, or maybe Canadian Tire?
I already sleeved my case fans (thanks to lowfat!). But, I want to do some more stuff now, so what the heck, let's punch some holes and paint some metal.
Old July 7, 2010, 01:02 PM
Supergrover's Avatar
I looked around local about a year ago and found that what was available was crap, ended up picking mine up from perpc along with some other stuff.
R.I.P.
Old July 7, 2010, 01:18 PM
Doh!!! Hummm, define crappy. Do you mean flimsy and/or won't fit properly and/or falls-off easily etc?
Old July 7, 2010, 04:10 PM
Toyoracer's Avatar
If you are looking for rubber channel try a glass shop or auto like Napa if small holes say under 1.5" home builders carry rubber grommets.
Laughing, Loving still Living
Old July 7, 2010, 04:48 PM
I mean stiff as in tight bends ( 90* corners ) dint work out so well. I used it for a back plate hole and wiring hiding hole, back plate was a square cut the wiring was rectangular, Imageshack - dscf3082.jpg.
This was what I ended up using, it comes in large too since you are looking for 1/4" Channel Molding - Small [CMOLDING-SM] : Performance-PCs.com, ... sleeve it and they will come
R.I.P.
Old July 7, 2010, 05:16 PM
ohhhhhhh, i see what you mean now... tight bends definitely won't work... well, i'm gonna keep looking around like Toyoracer suggested, and if it comes down to it, i'll get them from performance pcs like u did...
thanks!
Old July 6, 2012, 11:56 PM
The stuff from this company is about 1/4" and its pretty flexible u-channel ive used it on my 600T for couple mods.
Computer Modding Rubber U-Channel Rubber Window / Fan Molding | eBay
[FS] LG Flatron Wide 19" LCD DunF88 Buy/Sell & Trade 16 September 3, 2009 03:15 PM
Samsung 2253BW 22" Wide LCD Monitor-BLK Mr. Gruntsworthy Display Units 4 October 21, 2008 07:21 AM
FS: Dell Inspiron 1300 Laptop / 15.4" Wide CMetaphor Buy/Sell & Trade 20 July 9, 2008 05:42 PM
I swear I looked far and wide, but I need someone to explain "strapping" to me donimo Overclocking, Tweaking and Benchmarking 21 January 12, 2008 03:20 PM
Looking to buy my first 22" wide screen monitor Canadianguy Display Units 37 November 19, 2007 06:56 PM
