  #21 (permalink)
Old July 2, 2010, 12:36 AM
Hannes's Avatar
Originally Posted by TheGrapist View Post
epic pics!
Thanks, the 5-6(?) last pictures are just done in a haste and origins from Jpegs, I'll update them with RAW's when I have a program that can read 'em again.
Originally Posted by miggs78 View Post
What a way to show your work, with some awesome photography.. I admire your work, and off course like others. can't wait to see more :p..
EK FTW man!!.. Awesome stuff.. :)
EK FTW! ^^, They do really nice stuff and I'm honored to "represent" them with this build. I'm flattered for real that you admire my work. It's heartwarming.
Project Echo | Fractal-Design Array Rev2 | i5 750 | DFI LANPARTY MI P55-T36 | 2x2GB A-Data | Fractal SFF 300w MDPC-X sleeved orange and black | HD5870 | Kingston V-Series 64GB SSD | 2TB HDD | EK Supreme HF | EK-DCP 4.0 | EK Multioption 250 RES | EK-CoolStream-RAD XT 240 | EK-CoolStream-RAD XT 120 | EK-PSC Fitting 12mm - G1/4 Black | 5870 fullcover block |
  #22 (permalink)
Old July 2, 2010, 02:04 AM
m1dget's Avatar
I really like the idea behind the big case and the small board. Very nice :)
"NIX is a classic example of security through obscurity because there is no real monetary reward for crackers and hackers to break Linix" -AkG
  #23 (permalink)
Old July 3, 2010, 01:06 AM
Hannes's Avatar
It's a great way to store your stuff, but that's not the case I'm going to use.
  #24 (permalink)
Old July 5, 2010, 01:40 PM
Hannes's Avatar
Previously posted Jpegs
http://i48.tinypic.com/e00bnm.png
http://i47.tinypic.com/72d6rp.jpg
http://i45.tinypic.com/xfrn2p.jpg
http://i47.tinypic.com/2cpx55j.jpg
http://i46.tinypic.com/w9uxw8.jpg
http://i47.tinypic.com/2elqsk6.jpg
Updated raw-PNGs!
And some random pictures to celebrate that I've gone over to full manual! Hurray!
And some because I'm bored.
  #25 (permalink)
Old July 10, 2010, 12:26 AM
CroSsFiRe2009's Avatar
Gonna bump this up for updates since this is such an awesome build. (I'm a bit slow in noticing this but those UCTB12 fan's look amazing) When you get it running can you give a summary of how loud/estimated cfm of the fans and the possibilities of wiring my own leds in the precut holes? I'm thinking of picking up a few for my own rig...or possibly copying your entire build :P. I've had my mind on almost exactly the same items
  #26 (permalink)
Old July 11, 2010, 06:10 AM
Hannes's Avatar
Appreciate the reason you bumped this thread mate. The fans are awesome, and cheap! There's premade ledholes for you on this fans. So it's just to put some leds in and make 'em disco. I haven't actually tested 'em yet, so can't give you any data on that yet. They've the same design as the magma and the white fan, whatever name it had. So probably somewhat like them.
It's very fun to build so do give it a try mate!
Here's some updates for you. :D
24pin ATX
2x PCI-e 6pin
Have molex, Sata and the newly molded 8pin atx to do before it's finished.
  #27 (permalink)
Old July 11, 2010, 07:49 PM
Realityshift's Avatar
Wicked build Hannes, I love the highrez shots of the parts, what camera are you using for these?
The Builders Hammer
  #28 (permalink)
Old July 12, 2010, 06:36 AM
misterd's Avatar
Incredible work. Both in building and in capturing it visually. Cheers Hannes!
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
  #29 (permalink)
Old July 12, 2010, 02:07 PM
Hannes's Avatar
The Nikon D40 with the stock objective.
Thanks man! :D
  #30 (permalink)
Old July 16, 2010, 12:03 PM
Hannes's Avatar
How 'bout some pictures ay?
I've fitted the 240 radiator, moved the PSU mount 1cm and decided to move the PSU completely to the middle of the case. Some interesting times are to come!
Tags
ekwb , enermax , fractal-design , hannes , project echo
Project: PrometheusCU - Update #1 - Dec 3rd 08 SaibotC Case Mods, Worklog & Gallery 341 October 16, 2015 09:56 AM
Project X: Uprising!(May 21-23,2010) $5000 in prizes. Calgary Project X Canadian LAN Parties & Events 8 May 27, 2010 03:43 AM
[Project] - Wood case Behemoth- Case Mods, Worklog & Gallery 3 May 2, 2010 11:20 AM
Project X: Uprising! (April 16-18, 2010) Calgary, Alberta Project X Canadian LAN Parties & Events 30 April 2, 2010 06:22 PM
