Originally Posted by gingerbee just a thought but have you really overkilled it with rads even with cooling everything you have way more rad then needed unless your going for a crazy overclock? we always overdue water cooling |
I hear ya, but I feel the opposite. So let's agree to disagree
Why run water if you're not OC'ing the shit out of your gear? The majority of people run far too little rad for their setups. When I see CPUs and SLI setups being cooled by a triple rad I want to scream...
Granted, there's lots of factors that should be considered when determining the needs of a water setup, but when it comes to dealing with heat (our nemesis) you can never have too much rad, only too little. In my case (believe it or not) I don't have room for shrouds or a push/pull config, so I'm making up for the "inefficiencies" by adding additional rad space.
For this build, I'm looking at 2 CPUs, 4 GPUs and the chipset... so that's the equivalent of a dual rad per block/processor a push config... hardly overkill IMO.
Originally Posted by martin_metal_88 Their will be so much tube that it will probably not look clean anymore? |
I will, at most, be running 2 loops. I hope only have 1 loop, but that will depend on the chipset block... unfortunately, there are no chipset blocks on the market yet, so I will have to wait before I can finalize my setup. Besides, my builds are never messy... ;)
