  #51 (permalink)
Old June 9, 2010, 09:32 PM
Liu Kang's Avatar
Thx for the help, lowfat, SugarJ... pc-canada and 1c2c were the only ones I had found earlier.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
  #52 (permalink)
Old June 9, 2010, 09:34 PM
SugarJ's Avatar
NP. I want to see this beast in action.
It's on wheels, right? Otherwise you'll need a forklift to move it. :)
  #53 (permalink)
Old June 9, 2010, 10:35 PM
AmuseMe's Avatar
Kang, what is it that you do for a living?
DEAD CA$H
  #54 (permalink)
Old June 9, 2010, 10:51 PM
Liu Kang's Avatar
All Mountain Mods Ascensions (and UFOs I *think*) come with castors, so yes, it's on wheels.
I work hard and get nice tax returns ;)
LK
  #55 (permalink)
Old June 10, 2010, 04:04 AM
OMG, he works for the Canada Revenue Agency!
I am constantly checking this thread for your build progress.
  #56 (permalink)
Old June 10, 2010, 05:18 AM
gingerbee's Avatar
nice build liu but 600 bucks on rads those tax returns must be real nice. lucky bastage but buying gpu based on the pcb is down right silly, enjoy
  #57 (permalink)
Old June 10, 2010, 05:49 AM
Liu Kang's Avatar
I'm trying to keep up, just been busy with school and work. I ordered the GPUs from DirectCanada yesterday (2 x 5970s) so all I have left are the procs and I can throw this bitch together and start testing.
I won't disagree, but I'm just not willing to throw a green/red/blue card into my rig... looks matter to me :) Shallow, I know...
Thanks for all the kind words, gents.
LK
  #58 (permalink)
Old June 10, 2010, 06:55 AM
fishingfanatic's Avatar
Smile Case Mods ,Worklog Gallery
This thing is gonna be over the top. Please keep those pics coming. Would love to see some benching results on this beast! Good luck with the build, though it sounds like this is just another build for you. How do you rate a server's performance any way. I know, another noob question from a beginner.
  #59 (permalink)
Old June 10, 2010, 07:03 AM
AmuseMe's Avatar
I was thinking more about the TWO ~$2000 CPUs he is putting in there?
Kang, since you are going crazy allready with this, will we see an Iwaki!?
DEAD CA$H
  #60 (permalink)
Old June 10, 2010, 08:25 AM
Liu Kang's Avatar
Actually, that's probably the most useful question asked so far... My intent isn't really as much to build a "server" as it is to build the ultimate work station and gaming rig. While I believe 3dmark/vantage/cinebench/etc are all over-rated means of gauging performance, I will run them anyways to see how/where I can improve and optimize my machine. That being said, stability is as important as performance, so I will also run the "usual suspects" of torture test apps, like Prime95.
Personally, I'm most interested in testing the read/write of the SSDs and my PPD in both Folding and the World Community Grid.
As for true server testing, you're looking at a whole different ball game where you have to consider everything from failover to load balancing to network related tests... all tests I couldn't care less about during this build. :)
No, I'm not a fan of the Iwaki. While it's a fantastic pump, I've always felt it's important to build redundancy in a loop, in other words, use multiple pumps just in case a pump fails. There's something about running 2 Iwakis that makes me think my blocks, tubing and rads would explode ;)
I have a few Laing DDC 355 pumps on hand, so I will most likely run a single loop with 3 pumps in series or multiple loops with 2 pumps in series. All of this will depend on the SR-2 chipset waterblock I use, unfortunately, none are available yet.
LK
Project: i7³ Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 06:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
