  #21 (permalink)
Old June 5, 2010, 08:59 AM
Liu Kang's Avatar
Originally Posted by Rison View Post
where did you get the EVGA Classified SR-2, and what does it cost? - can't seem to find it anywhere
I did a really quick/cheap unboxing thread here: Got my SR-2 *pics*
Long story short: you can only order directly from EVGA: $600USD for the board, $30USD shipping, $~100 duty/brokerage.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
  #22 (permalink)
Old June 5, 2010, 09:55 AM
AmuseMe's Avatar
I would have told them to send me a custom quote for (I assume you used UPS because of brokerage) Worldwide Expedited/ Express Shipping. It would have been about $100, but no brokerage or custome fees.
DEAD CA$H
  #23 (permalink)
Old June 5, 2010, 10:17 AM
"It barely fits in my home office... it's 35 inches tall, 18 inches wide and 24 inches deep. You need some serious space for any of MM's extended cases."
  #24 (permalink)
Old June 5, 2010, 12:06 PM
Liu Kang's Avatar
I threw in some parts so I can start planning (loops, wiring). I'm really surprised just how little room there is in the case. I know, sounds dumb, but the sheer size of the board takes some getting used to.
You'll see in the pic below that there's only ~5 inches between the board and the rad. I had purchased 2 UN Design brackets and was going to use them to mount the new EK reservoir to the rads but that may not longer be possible (the new model is 10mm larger in diametre).
I'm starting to rethink these 120x38mms at this point... kinda funny that 13mm might make all the difference in such a large case.
There's been lots of e-bitching about the MM SR-2 motherboard tray. Folks say it bends really easily. In this pic you can see it is slightly tilted. The huge cut out in the tray, allowing access to the CPU back plate, diminishes its rigidity. It concerns me a little, but if it becomes a real problem it will be easy to fix.
mmmmm... ddr3 2000
LK
  #25 (permalink)
Old June 5, 2010, 12:13 PM
Liu Kang's Avatar
Originally Posted by AmuseMe View Post
This is going to be great Kang! Is the wife cool with this or did you just tell her to 'HTFU'?
No, I told her to GTFOOMOAGTTKAMMAS! (get the **** out of my office and go to the kitchen and make me a sandwich) Seriously though, she's cool with it... I just took her on a vacation and bought her a pair of shoes, so I'm good.
LK
  #26 (permalink)
Old June 5, 2010, 12:54 PM
Digikid's Avatar
JEALOUS!!!
and if you want really GOOD video cards....go with ATI right now as the Fermis are junk. Too hot and the power requirements are way out there.
Couple of 5970's.....WOW!!! Way better than anything Nvidia can do.
What you gonna use this system for?
  #27 (permalink)
Old June 5, 2010, 01:20 PM
Polygon's Avatar
Looking good, I second that you should go with ATI... it will also fit the red/black theme.
'Do not wish for easier lives, wish to be stronger men'
DreamRealeSports.com
  #28 (permalink)
Old June 5, 2010, 02:27 PM
A couple of T or L brackets mounted on the back of the tray along its length would solve that problem easily, if there is sufficient room behind the tray (it looks like there is).
  #29 (permalink)
Old June 5, 2010, 02:45 PM
Liu Kang's Avatar
Mostly online shopping and word processing... a bit of Farmville too.
Pft! All I care about is the black PCB, you can rest assured that the nasty stock heatsink of any GPU will be removed promptly :)
LK
  #30 (permalink)
Old June 5, 2010, 03:43 PM
Digikid's Avatar
DEATH TO FARMVILLE!!!!
Project: i7³ Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 06:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
