Old June 2, 2010, 07:38 PM
Default I5 Build w/friend's help ;)
Yeah after long time of planning I finally decided to buy parts. my parts are:
Case: CM 690II basic
CPU: i5 750
Mobo: ASUS p7p55d
PSU: M12D Seasonic 850w modular
Ram: G Skill Ripjaws DDR3 1600mhz 2x2 gb 1.5v kit
CD: Samsung SH-S243D/BEBE 24X Black DVD Writer SATA OEM
HDD:WD Caviar black 640gb 64mb cache(plan to raid 0 maybe later)
HeatSink: Well i know its some zalman heatsink, currently my friend holds the box well i don't have. With 2 slip streams medium airflow 120mm fan.
Case Fans: 2x Slip streams medium airflow 120mm fan.(plan to get 2 more later maybe 3)
GPU:Currently using a 9800GT from XFX(planning to upgrade to a 5850 or 5870)
Well I got most of my parts except my mobo, that is coming a day late. So while I waited me and my friend just setup some of the parts since my mobo is coming in tmr.
PARTS BEFORE ASSEMBLING
Yeah so no mobo or heatsink yet. but thats everything else i basically need to get a computer running. so I so far put in two fans one exhaust up top, one intake on the side. put in my HDD, Optic Drive and PSU so far
Whole View
Side Fan
(Can't put two i believe my heatsink will be in the way)
Top Fan
Optic Drive
(i don't think it looks as great but atleast its black ;) )
HDD
Also from the whole view you see i took out 4 of the HHD carrying cases or whatever they are called. and the two rails since i will be only having 2 HDD at most. Also no close up on my PSU, but i don't think its a really big issue.
MOBO comes in tomorrow and same with heatsink and i think the rest of my build will be done and ready to go. So hopefully updates tomorrow. Hopefully i got good cable management too :)
Old June 3, 2010, 12:50 AM
Great stuff. Good luck mate!
Old June 7, 2010, 04:13 PM
Kayen's Avatar
Dude. You sure you want to go ahead with this tonight .. i can come do it tomorrow night ... but w.e floats your boat.
Take pics.
Tags
i5 750
New i5 build for friend. TheWanderer New Builds 5 May 2, 2010 02:20 PM
Another build for a friend. Kayen New Builds 22 November 3, 2009 10:46 PM
Build for friend Kayen New Builds 7 August 24, 2009 08:44 PM
Build for a friend lanken123 New Builds 5 May 6, 2009 08:54 PM
Build 4 a Friend. BALISTX New Builds 5 June 25, 2008 01:21 PM
