  #21 (permalink)
Old May 29, 2010, 10:52 AM
I'm guessing that's the board 3oh6 was selling.
  #22 (permalink)
Old May 29, 2010, 03:45 PM
mattlef's Avatar
So here is the update I promised,
First I want to promise for the lack of progress pics. I think I may have a bit of ADD because when I get to something, nothing's gonna stop me from getting it done. lol
I started pretty much everything on Friday. The last of my packages came in, and I thought you myself, "Matt, you have a few hours..... get this put together!"
First up was the GPU.
She started out as this, then met the twin turbo.
about 15 minutes of metal snipping and quite a bit of erasing later, she looked almost perfect.
So I plugged in the fan header and tried to hide it the best I could
Now, I received the cooler a week before and was ever so tempted to install, but for some reason AC had forgotten a few screws. So I had to wait for them to come in....
but voila
Next up was installing the motherboard on the tray.
Easy enough, I just wish i had the IO port. Might contact EVGA for it later on.... dont know if i'll paint it white or black. Then popped in the Dominators and mounted the new Push-Pull config'd Scythe S-Flex
1600'd H50.
Sleeving the fan cables wasn't difficult at all, thankfully, but just my luck one has a low frequency bearing buzz, and i'm out of sleeving.... oh well
Installed the GPU...
But wait, where are the HDD's?
So with everything together this is how she looks....
Oh, and just in case you guys were wondering why I spent so much time sanding that Plexiglas....
it was to get this effect:
Shes done for now, more to come, so keep on the look out for updates.
All that is missing is a soundcard, mostly because front audio wont reach on this board :S
Doing a H50 mod soon, so watch for that as well ;)
CC-HotSpot Host
YouTube Instagram Twitter
  #23 (permalink)
Old May 29, 2010, 08:35 PM
AmuseMe's Avatar
An H50 mod eh? Is it going to be a different radiator that you will use?
  #24 (permalink)
Old June 8, 2010, 01:09 PM
mattlef's Avatar
I'm looking at adding a better 120mm rad, better tubing as well as as a res,
Here is a few other pics of the rig thus far....
CC-HotSpot Host
  #25 (permalink)
Old June 8, 2010, 01:21 PM
CroSsFiRe2009's Avatar
That is quite the sexy piece of kit. My only question is why you didn't take apart the stock cooler and use the stock basplate instead of using the Twin Turbo mem/vrm heatsinks. The Stock plate seems to provide better cooling than any of the small heatsinks that are provided from what I've read
  #26 (permalink)
Old June 8, 2010, 01:29 PM
mattlef's Avatar
Thanks
lol you've caught onto my next update lol.
I'm working on grinding down the stock-plate so that the cooler fits flush..... a little difficult to do with the dremmel I have, its not anywhere near as strong as it should be :S
CC-HotSpot Host
  #27 (permalink)
Old June 8, 2010, 05:22 PM
You may as well just replace the thing with a real watercooling kit in that case, since the only things you'll be keeping are a weak pump and an average-quality block.
That's because you bought a cordless Dremel...
  #28 (permalink)
Old June 9, 2010, 07:11 AM
AmuseMe's Avatar
Mattlef, this is looking good
  #29 (permalink)
Old June 9, 2010, 07:42 AM
martin_metal_88's Avatar
nice one mat! this is clean and good locking! I like that!
[WTB] cooler master stacker bigpino Buy/Sell & Trade 1 March 16, 2009 12:49 PM
[WTB] CM Stacker 810 CMetaphor Buy/Sell & Trade 5 March 11, 2009 05:27 AM
CM Stacker Mod CanadaRox Case Mods, Worklog & Gallery 19 July 18, 2008 07:20 PM
Stacker 830/832 log. lowfat Case Mods, Worklog & Gallery 25 January 26, 2008 02:12 PM
2 PSUs in a Stacker Babrbarossa Power Supplies 14 October 16, 2007 07:36 PM
