<~----> Cooler Master 690 II Advanced ReD PainT... - Hardware Canucks
Old May 12, 2010, 04:14 PM
blueweb's Avatar
Default Cooler Master 690 II Advanced ReD PainT...
26 July 2010 : Latest Update with the chrome strips painted.
YouTube - 006 Cooler Master 690 II Advanced Build Pt.3 Complete Overview, Red Paind and Mods 24June2010
Pictures from 18th of June 2010
Old May 12, 2010, 04:52 PM
fishingfanatic's Avatar
Smile PC Builders and Tweakers Corner
Looks good. CoolerMaster is a good case, and I like the red. I keep thinking that I should paint/mod mine. I like the look though. Mine is a Cosmos S 1000. Time to save some toonies for Mnpc maybe? Great work, and I love his custom painter. You make it look like you've done this before.
Old May 12, 2010, 05:20 PM
blueweb's Avatar
Thanks,
Yeah every since I painted my ram cooler black at first I just became addicted to painting stuff so I saw Oliverthefrenchy on youtube paint his so I just decided to do mine and thankfully Canadian Tire had the same paint that he used. No sanding required, this paint is like rubber.
Old May 13, 2010, 12:15 AM
CroSsFiRe2009's Avatar
Interesting, never seen many people use lacquer, is it glossy?
Old May 13, 2010, 02:04 AM
blueweb's Avatar
I would say It's closer to matt than glossy, Became more glossy as it dried now like 30% glossy :P
I really like the way it looks.
Old June 1, 2010, 07:56 AM
Nice paint job there.. Feel pitty for you on the cable management at the back :p... aight j/k :D
Red looks lovely.
Old June 1, 2010, 10:32 AM
I don't like the glossy look :( but nice paint job :)
Old June 1, 2010, 09:22 PM
blueweb's Avatar
Yes... I did have to cut off some un-used power cables to make things look better, my first time adding sata power connectors, almost stabbed myself with the screw driver a few times but I made it.
The split sleeving was perfect for a lazy person such as me, it made things alot easier.
My camera kinda exaggerated the color saturation intensity of the red and the flash does make it look abit glossy but looks better in real life imo.
Now I am just waiting on some red coil for the H50, a cheap addition that should look good :)
Old June 1, 2010, 09:32 PM
Kayen's Avatar
Dude. where did you get the window ... ?
Old June 1, 2010, 10:20 PM
blueweb's Avatar
At the CM Store but it's not there so it must be on back order again, I waited a month to buy mine at the end of March. I am planing of making my own custom window without a fan hole with my oem panel if that turns out nice then will sell the one I ordered... yeah.
Tags
cooler master 690
Comment Thread for Cooler Master 690 II Advanced Video Review SKYMTL Cases 38 August 18, 2011 12:16 AM
Cooler Master Begins Shipping Windowed Side Panel for 690 II Case FiXT Press Releases & Tech News 7 March 13, 2010 03:21 PM
CM 690 Advanced II Vdub90 Cases 15 February 18, 2010 12:51 PM
Cooler Master 690 II Advanced Mid Tower Case Leaked FiXT Press Releases & Tech News 7 December 8, 2009 08:29 AM
