Old June 1, 2010, 10:42 PM
dustin1706's Avatar
The red highlights look sweet!
Old June 2, 2010, 06:50 PM
aviduser's Avatar
where did you get the xiggy fans? I can't find those anywhere, they look sick as well.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old June 2, 2010, 09:48 PM
Kayen's Avatar
Originally Posted by blueweb View Post
At the CM Store but it's not there so it must be on back order again, I waited a month to buy mine at the end of March. I am planing of making my own custom window without a fan hole with my oem panel if that turns out nice then will sell the one I ordered... yeah.
If you indeed forgo that option, gimme a shout, i'd definitely be interested !
Old June 4, 2010, 03:34 PM
blueweb's Avatar
Here you go :) :
Newegg.ca - xigmatek fan
or
Anitec.ca - Heatsinks & Fans
Old June 18, 2010, 06:09 PM
blueweb's Avatar
28JUN10
Performance PC's has started selling the side panel for $24.99
They even sell a precut side panel without the fan but the catch is you have to buy the case with it for $169.95
Old July 4, 2010, 12:41 AM
blueweb's Avatar
04July10 Update
Removed the front and top chrome strips and will paint them red.
I was surprised how easy the were to remove, just using a flat tip screwdriver and prying the tabs just enough that you can push down and they pop right out.
I had to remove the mesh since the paint chipped, nothing noticeable but the minor things bug me so they are all in my garage now waiting for some clear coat, something I should of done the first time :P
I think the best way to avoid scratches will be to insert the mesh first then the strips... yeah.
Tags
cooler master 690
Comment Thread for Cooler Master 690 II Advanced Video Review SKYMTL Cases 38 August 18, 2011 12:16 AM
Cooler Master Begins Shipping Windowed Side Panel for 690 II Case FiXT Press Releases & Tech News 7 March 13, 2010 04:21 PM
CM 690 Advanced II Vdub90 Cases 15 February 18, 2010 01:51 PM
Cooler Master 690 II Advanced Mid Tower Case Leaked FiXT Press Releases & Tech News 7 December 8, 2009 09:29 AM
