-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   Completed My Mini HTPC Build (bedroom PC) Mini box M350 (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/30983-my-mini-htpc-build-bedroom-pc-mini-box-m350.html)
CoolHandL April 13, 2010 05:00 PM
Yes im whoring my rigs out, this is my 3rd gallery post but i have 3 seperate rigs for three different tasks(i won post pics of my original P4 build)
My Mini ITX build in a M350 Mini box case
Case: Mini-Box 350
Mobo: Zotac ION-ITX N330 A-U model (included PSU and Brick)
RAM: Kingston KVR800D2N5/2G DDR2 800MHz
HDD: WD Black Scorpio 2.5 160GB Sata 7200RPM
Fan Controller: Zalman Fanmate 2 (keeping it at 2000RPM keeps stock fan silent and temps down to 45*C at full load Only sound is minimal vibration from HDD)
http://i864.photobucket.com/albums/a...0/IMG_1892.jpg
http://i864.photobucket.com/albums/a...SETupfront.jpg
http://i864.photobucket.com/albums/a...niItxBRTop.jpg
http://i864.photobucket.com/albums/a...XCAseonTop.jpg
http://i864.photobucket.com/albums/a...ITXFanmate.jpg
YEP ITS OVERCLOCKED
http://i864.photobucket.com/albums/a...Mini-ITXOC.jpg
http://i864.photobucket.com/albums/a...ini-ITXTop.jpg
http://i864.photobucket.com/albums/a...closeuptop.jpg
http://i864.photobucket.com/albums/a...itxcpuside.jpg
http://i864.photobucket.com/albums/a...fanmateram.jpg
http://i864.photobucket.com/albums/a...itxhddside.jpg
antiacid April 26, 2010 03:25 PM
how silent does it run?
CoolHandL April 26, 2010 04:07 PM
with the zalman fanmate it runs silent, with the fan at 100% you can hear it. I'd say its inaudible while watching a movie from bed, and when the room is silent and its time to go to sleep its still inaudible, i have to put my ear to it sometimes to make sure the fan is still spinning.
_dangtx_ April 26, 2010 04:44 PM
how do you like the hdd? ive put a few wd's in my laptops. usually the green drives are the best for sonority, access times of ocurse lacking a bit
CoolHandL April 26, 2010 07:25 PM
i like the wd 2.5 blacks they work great and are fast!!, not loud at all the run a bit hot though. i have one in my living room htpc as well.
