  #21 (permalink)
Old April 15, 2010, 04:06 PM
Patramix's Avatar
Good news everybody, Bender is here :D
now i need to find my futurama dvd's
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
  #22 (permalink)
Old April 18, 2010, 07:21 PM
Photograph's Avatar
The last $5.00 has been spent:
$2 - Scrap piece of white acrylic for front panel
$1 - Scrap piece of hexagonal mesh
$1 ea. - Two switches
The piece of white acrylic was just big enough to work but did crack a few times when cutting (I a complete noob when it comes to acrylic but I am learning ), I used the sheet anyways after a few repairs as to keep within my budget:
So the front panel is completed, and if you are wondering about the 200mm Antec Big-Boy in there it was a freebie as well as one of the blades had snapped off. A dab of superglue and a few minutes of patience and I have am almost as good as new fan for free
More updates to come soon.
HWC Folding Rig: Gigabyte H55N-USB3, Intel Core i3 530 @4.6Ghz, GTX 460
  #23 (permalink)
Old April 22, 2010, 08:21 AM
Photograph's Avatar
To continue my progress:
I built a sleeved power switch from my $1 button and a reset header pulled from the initial case:
I installed the switches including an on/off switch for the case lighting:
The Silverstone 850W PSU fits...after a little coaxing:
And now it's motherboard modding time
First target will be the CPU MOSFETS seen below:
Small Heatsinks with a penny for size reference:
And the taller heatsinks and thermal adhesive:
So I dabbed a little T.A. on the MOSFETS and got to work:
And voila; I should be able to pump a little more voltage through here now and you may have noticed the pressure mod done to the Vendetta 2 by adding some spacers to increase spring tension:
The next target was the Northbridge, after replacing the stock TIM with MX-2 (I did the Southbridge too) I added a 40mm fan. You can also see that I have added heatsinks to every MOSFET on the entire board.
A fan is OK and all but why not make it work better with a shroud? So I made a little acrylic shroud for it (that's a dog hair on the table if you were wondering):
And here is the installed shroud:
And then i got to work on something for the Bender figure using Nylon ball bearings and 1/8" metal rod:
Can you guess what it is yet?
And here's Bender with the finished product in his new home:
All parts have been assembled:
Shot of the cable routing:
And powered up with lights on! It lives!
Thanks for looking everyone, now to get this machine set up for the Chimp Challenge
  #24 (permalink)
Old April 22, 2010, 08:43 AM
misterlarry's Avatar
Nice work Photograph & great build log. Gotta love Bender.
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
  #25 (permalink)
Old April 22, 2010, 12:49 PM
chrisk's Avatar
Folding Captain
Like I mentioned in another thread, good work! The Bender figure was an excellent touch, as was the protein!
Fold for team #54196
  #26 (permalink)
Old April 22, 2010, 12:58 PM
I'm jealous of your talents !
"What is the colour when black is burnt ?" - Neil Young
  #27 (permalink)
Old April 22, 2010, 02:27 PM
gingerbee's Avatar
very very nice build great use of an old case.
  #28 (permalink)
Old April 22, 2010, 02:44 PM
Dead Things's Avatar
Excellent imagination and even better execution! Superb work! Here's hoping the boss allots you a little more budget room to work with next time!
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
  #29 (permalink)
Old April 22, 2010, 08:46 PM
Photograph's Avatar
Thanks a ton everyone, I am happy to report that Bender is now folding with very respectable temperatures so far
  #30 (permalink)
Old April 22, 2010, 08:52 PM
stoanee's Avatar
I love it!!
heatware
Tags
case mod , folding@home , ghetto , low budget build
Low Cost - High Performance? TokeR New Builds 18 February 8, 2010 05:22 AM
AMD Extends Mainstream Processor Family with Low Cost Athlon II Series FiXT Press Releases & Tech News 0 October 20, 2009 11:27 AM
[FS] BNIB High End Radiator 240 TFC **High Performance** qaz393 Buy/Sell & Trade 4 August 17, 2009 01:47 PM
Looking for a cost/performance laptop. appplejack New Builds 13 April 20, 2009 07:43 PM
Help, NEW PC Low Performance mewbomb Overclocking, Tweaking and Benchmarking 17 November 8, 2007 10:03 AM
