Old March 25, 2010, 10:32 AM
Patramix's Avatar
Default simple 800D system *pic heavy*
Hello everyone, here is my new 800D, still WIP, still waiting on purolator to ship my 2nd shipment
here is the system specs :
Corsair Obsidian 800D
XFX 850W Black Edition
ASUS P7P55D-E Pro
Intel Core i5 750
G.SKILL F3-12800CL9D-4GBRL Ripjaws PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24
Coolermaster Hyper 212 Plus
2x 1TB WD Black
2x Seagates 7200.12 500gig in raid 0
1x 500gig WD caviar
Audigy X-FI Fatality platinum (old pci version)
here's the new Case
just to show what the old system looked like : original thermaltake Armor case with 25cm fan.
side by side of the old armor and 800D :
and now what my old system looks like in the new case :
yeah thats a HDT-S1283 with 2 fan's, had to invent a way to stick a second fan on it, witch only improved the temps by 1c (with not perfect past job)
paper clips FTW lol
full album here : Picasa album
purolator is supposed to drop off my 2nd shipment with new mobo/cpu/ram, once that is installed i can begin to install my lights and other stuff inside the case, square up the wiring. the 24pin connector is realy tight fit with that mobo, hoping the p7p55d is just a tad lower.i do plan to resleeving most of the wires once i get the time for it as i don't like to see the dam color of the wires, the XFX Sleeving is ok, but this case demands slightly better Sleeving.
also whant to add a fan controller, i gota say i kinda like the looks of the Zalman ZM-MFC3.
ill post more pics once more work gets done.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Old March 25, 2010, 10:53 AM
Patramix's Avatar
well i just finished typing this and puro showed up...
time to back up and reinstall everything lol (totaly forgot to back up my stuff lol
My Boinc Stats
Old March 25, 2010, 12:18 PM
Digikid's Avatar
LOL! Wow what a messy desk!!! j/k
Thanks for the pics!
Old March 25, 2010, 12:28 PM
Patramix's Avatar
lol you dint see the other side
this summer am planing to redo my whole desk, make it more ergonomic and what not, and try to get everything i use in rang of my arm's hehe
My Boinc Stats
Old March 25, 2010, 12:33 PM
[quote=Digikid;353690]LOL! Wow what a messy desk!!! j/k
+1 LOL
Old April 6, 2010, 03:31 PM
Patramix's Avatar
lol that side of the desk isnt that bad
thats an other project i have for this summer
well ive done more work on it
shipment #4 came in, my 2 R4's for the 212+, max temp don't go over 63, about 4-7C difference from stock.
i repainted my CC converter, was an ugly blue, now its flat black and almost matches the case perfectly, kinda cool for a old can of paint from my last mod.
and the painted version
i know its not the best wirering job around(ive actually made it look better but forgot to take a pic), but i was kinda looking into making my own custom wires so i could get the length perfect for each component, but that's for later. (no its not an IDE cable, its the but ugly link for my X-FI platinum(also planning a custom wire)
also installed my blue cathodes, i installed them way in the back(top part behind where the rad would go) and it creates just a nice glow in the case without being over powering.
yes its crooked, wont fit the way i want it with the length of cable it as, but you really cant see it normally hehe
next few steps include sleeving the wires and possibly custom wires.
i am looking into doing a new mod project with my old TT Armor case(my @home/fileserver) system, involves some painting(although i am not the best at it) and possibly a full dismantle and rebuild of the case itself. if i can figure out what i want to do with it.
now i need to find a good place for my CC switch.
My Boinc Stats
Old April 15, 2010, 05:35 PM
Patramix's Avatar
well today i was greeted with a very nice box of toys from Nils, my MDPC-X sleeving was here :)
humm i hope that's a drawings of whats inside... hehe Nils is always superb
sorry for bad light not sure where i put my diffuser and i my good cam broke.
now for the good :
that's just part of it, forgot to take a pic of the rest.
now for my very first sleeving attempt, on a simple Fan(its and R4)
now i think i did ok.
5 more (all R4 hehe) to go, then onto Sata cable's and then PSU... think that's my weekend project cause its gona take a while to do all of it.
MDPC-X is awesome stuff.
My Boinc Stats
Old April 15, 2010, 08:06 PM
Patramix's Avatar
no pics yet, but ive done a little work,
ive changed the 2 fans on the hard drive bays, put a R4 on the lower bay(next to PSU) and a Noctua NF-P14FLX 140MM Ultra Quiet Cooling Fan 750-1200RPM 71-110M3/H 10.1-19.6DBA on hot-swap bay.
the noctua as a decent static pressure for the size, so far they are doing perty darn well, my hdd's look to be almost 7C lower now.
now to finish sleeving
My Boinc Stats
Old April 15, 2010, 09:36 PM
Wow, nice. It looks so much cleaner.
Dell Studio 14z Review (Image Heavy) Wolfx25 Member Reviews 11 September 29, 2009 01:38 AM
My 'green' HAF932 *heavy pics* Lamb Cases 25 August 31, 2009 11:28 AM
Possible new Rig. Heavy OC and Gaming Junglebizz New Builds 11 May 22, 2009 09:22 AM
X58 Motherboard roundup! (Heavy Images!) encorp Case Mods, Worklog & Gallery 23 December 5, 2008 10:13 AM
TF2: Heavy vs Scount enaberif Off Topic 2 November 10, 2007 01:42 PM
