Old March 13, 2010, 03:56 PM
MarkOne's Avatar
Default Ultimate WC system II
Oh yes an other one in work too,
Case : Mozart XT
CPU : i7-965 CO, so it need good cooling
CPU block : Koolance 360
Motherboard, Rampage II Gene
PSU : a Seasonic M12D 750W,
HD 2 x raptor 74 gb in raid 0 , 500gb blue
OS : 7 Home Premium x64
Old March 13, 2010, 04:33 PM
ZZLEE's Avatar
Whats the plan fore the other side off the exchager? Well water, Lake Water or big block rad,
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 13, 2010, 04:46 PM
MarkOne's Avatar
well water... have a look at his little brother tread
http://www.hardwarecanucks.com/forum...wc-system.html
Old March 16, 2010, 02:37 PM
MarkOne's Avatar
Just get the CPU , here we can see it with the stock cooling. soo cool those blue led on Intel cooler
what happen I see something new in the BIOS , I can rise the clock of the CPU
Old March 16, 2010, 06:39 PM
lowfat's Avatar
It is way too small for something like that I would imagine. It would need way more surface area for something of that magnitude.
Mael
Big Lian Li
Forever Alone
Old March 17, 2010, 08:12 AM
MarkOne's Avatar
ok I install the koolance 360 block on the Gene, it fit tight but it fit, I make some pre test , I use my Big water kit for bench test, very usefull, rad, pump and reservoir in the same unit,
I will make it work 24 hours to cure the paste , before mont it on the case I also install heat sink , the pre-owner have install one, I find it a good Idea, so I just replace the cooper one he put with aluminium .
Old March 17, 2010, 08:14 AM
Arinoth's Avatar
May be too late to ask now if you dont have screenshots when under air, would love to see the temperature difference of your new ultimate WC system and stock air, lol
Here I am: here I remain
Old March 17, 2010, 08:17 AM
MarkOne's Avatar
I have the same feeling to, but I have 2 of them... we will see.
you will not see this processor on air it was just for a post test.. but stock cooler who came with the EE processor are amazing, they blow a lot of air ,
Old March 17, 2010, 10:17 AM
MarkOne's Avatar
ok I receive finally the adapter 3/8 to 1/4 tread as you can see it's a little bit larger on the tread than the 3/8 barb fitting, it's not seating well on the heat plate exchanger, so I will be able to make the plumbing now and try it
we are talking of the tread when I say 3/8 .... the barb is a 1/2"
Old March 17, 2010, 11:01 AM
BigDogg's Avatar
What adapters are those (brand wise)? I just ordered some bitspower G3/8 - G1/4 adapters from Sidewinders should be here in a few days.
Ultimate WC system MarkOne Case Mods, Worklog & Gallery 67 March 15, 2010 01:09 PM
Windows 7 Ultimate for $10.50 misterd O/S's, Drivers & General Software 23 November 9, 2009 11:44 AM
THe Ultimate steal pRefy O/S's, Drivers & General Software 4 March 24, 2009 03:47 PM
64 Bit Vista Ultimate and Office Ultimate 32 Bit tyreman O/S's, Drivers & General Software 5 March 22, 2009 04:54 AM
Driverheaven's Ultimate Skulltrail Gaming System Benches Spaceman-Spiff Video Cards 4 August 19, 2008 02:55 PM
