Old February 24, 2010, 10:06 AM
lcdguy's Avatar
Default Project: The Horde
So i have decided to go about building a dedicated file server. It will called the horde. You will see why. This is a 4U 20 Drive rackmount SAS enclosure system. I ordered the parts i needed to start this today. Hopefully they will start to arrive in the next couple of weeks.
Case: Norco RPC-4220 4U SAS Backplane Case 20 drive capacity
Raid Card: dell perc5i SAS Raid Card
CPU: AMD A64X2 7550 2.5Ghz
RAM: 2GB PC-6400 DDR2
SAS Cables: 1x SFF8484 -> SFF8087 Multilane Cable (this one was a pain to find), 5x SFF8087 -> SFF8087 Multilane SAS Cable
SAS Expander: Chenbro CK12804 28port SAS Expander
PSU: Corsair HX750W PSU
Storage Drives: 8x 1TB WD Black
Boot Drive: WD Scorpio Blue
Everything is ordered or sitting at my home already.
Expect picture as stuff starts to arrive.
Old February 24, 2010, 12:20 PM
Rison's Avatar
right on, i'm interested on how this turns out! take some pictures when you start putting it together.
I haven't seen much on this case, let us know any issues ya run into.
Cheers.
I'll learn to manage my anger, when people learn to manage their stupid.
Old February 24, 2010, 12:22 PM
lcdguy's Avatar
i billing this has the poormans big file server. since you can get a moreelegant solution from supermicro but the case + expander is about double. One word of note the chenbro expanders only seem to be available through distributers so you will either need to know a reseller, be a reseller or look at the HP sas expander.
Old March 4, 2010, 08:51 AM
lcdguy's Avatar
update time.
so i recieved most of my hardware. However i still can't start my project for 2 reasons.
1. I am still waiting on the sas expander. I can't really use it without the expander.
2. The case i recieved was damaged. So i will either sit on it until purolator finishes it's claim process and i get a new one or i will get the expander and say fudge it and build it anyway (since it's superficial damage).
But most importantly (and more important than the expander.) is i got my SAS adapter cable for my perc 5i. It was incredibly hard to find a SFF8484 to SFF8087. I had to order it through the US.
Old March 4, 2010, 10:11 AM
misterd's Avatar
Is this a special adapter? My SFF8484 to 4 Sata was 20 bucks US shipped from China for 2x @ 0.5 Meters each.
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old March 4, 2010, 10:16 AM
lcdguy's Avatar
Because your cable is a SATA breakout cable. This is a SAS cable. Unlike some Sata Breakout cables SAS cables are generally diretional cables. So the one SFF8087 -> SFF8484 would not work as the direction has to be reversed. There is a big difference between SATA and SAS mostly being the number of deivces that can be addressed. (4 port breakout cable can hook up to 4 drives, 4 port SAS cable + SAS expander means you can connect a maximum of 125 devices per SAS channel IIRC)
Old March 4, 2010, 01:02 PM
misterd's Avatar
Cool, it was a quick reply before i had to run away @ work. Hope it works out well. I haven't even tried my Perc 5i yet, I really should though. Hope I don't have to do any pin mods.
Old March 4, 2010, 01:19 PM
lcdguy's Avatar
If you have an intel based desktop board (non server) then you need to do the pin mod if you have an amd/nvidia based board it should work as they don't use the offending item (Intel smbus) I use a peice of scotch tape and it works fine in my p5q pro.
Old March 6, 2010, 05:42 PM
Liu Kang's Avatar
Very interesting... looking forward to the pics.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old March 6, 2010, 06:14 PM
Babrbarossa's Avatar
OMG- WHAT are you storing on that beast?? You, my friend, have to share that pron collection
Project: i7 Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 07:53 PM
Cannot find stats on Horde's website? Dashock HardwareCanucks F@H Team 3 October 23, 2008 12:20 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
