So this is what has transpired. My lovely linksys w/ tomato has decided it no longer likes the internet. As such i am pissed at linksys for crappy hardware so have decidde to build my self a linux based router box. I am currently testing both pfsense and smoothwall. I am leaning towards pfsense since it's vpn support is much better than smoothwall (smoothwall out of the box only supports ipsec while pfsens supports, ipsec, openvpn and pptp). The hardware i am currently running my work around is overkill so i have ordered some more approiate hardware for the job. Here is the hardware layout.
Intel Atom 330 Board m-itx
Norco 2U Short Rackmount Case
Intel Pro 1000MT Dual Port NIC pcix
4GB Hitachi Microdrive
1GB DDR2-pc6400
Corsair VX550W PSU (overkill i know but it's a high effciency so that will help)
Addtronics CF->Sata Adapter
SATA DVD for install.
I currently have everything but the case (grrr, purolator hurry up already). Once i have that expect an update. Also keep an eye out for my new rackmount fileserver build. I think you will be pleasntly surpirsed but nothing on that for now
