-   Case Mods, Worklog & Gallery (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/)
-   -   "HARDWARE CANUCKS" Custom Case by Mnpctech (http://www.hardwarecanucks.com/forum/case-mods-worklog-gallery/28135-hardware-canucks-custom-case-mnpctech.html)
Mnpctech January 24, 2010 11:47 AM
"HARDWARE CANUCKS" Custom Case by Mnpctech, aka Candy Coated Billet Beaver.
http://www.mnpctech.3dpixelnet.com/p.../hc.beaver.jpg
This is a project for the people that are members of this joint, YOU!
The canvas is the Corsair Obsidian 800 Case.
http://www.mnpctech.3dpixelnet.com/p...library/hc.jpg
This will be another Insane Case Mod by Mnpctech.com
We ship to Canada!
You must email us your order
Include item description, size and quantity in your email
International payments by Paypal Only.
First Class mail can take 7 - 24 business days.
No tracking capability.
http://www.mnpctech.3dpixelnet.com/p...pctech.com.jpg
Here are some of Mnpctech's most popular case modding products!
Acoustical Sound Proofing Sheets for your PC
http://www.mnpctech.com/acoustical_p...ey_sheets1.jpg
Mnpctech is now stocking clear and colored sheets of cast acrylic for window mods
Colored Acrylic Computer Case Mod Windows
http://www.mnpctech.com/clear_acryli...ctech.com1.jpg
This is the Honeycomb Modders Mesh we used.
http://www.mnpctech.com/ModdersMesh.thm.jpg
http://www.mnpctech.com/mesh5.32.jpg
PC Cable management clamps
PC Cable Clamps
http://www.mnpctech.com/pc_computer_...h.com_demo.jpg
U-channel molding, U-channel edge molding for PC Mod Window
http://www.mnpctech.com/Uchannel1.jpg
Here is the 1/8" Aluminum Pop-Rivet we use for computer cases that we've dismantled for custom paint. Countersunk (Blind) for professional and clean look. Gripe range .092" - .125"
Pop Rivets For Computer Cases
You can get Black Pop Rivets from Mnpctech
http://www.mnpctech.com/pop_rivet_bl...sis_doomed.jpg
Copper Rivets
http://www.mnpctech.com/copper_blind...pctech.com.jpg
Pop Rivet Gun
Pop Rivet Guns
http://www.mnpctech.com/pop_rivet_bl...se_chassis.jpg
Ok, lets take a closer look at this Beast.
http://www.mnpctech.3dpixelnet.com/p...ibrary/hc1.jpg
http://www.mnpctech.3dpixelnet.com/p...ibrary/hc2.jpg
http://www.mnpctech.3dpixelnet.com/p...ibrary/hc3.jpg
http://www.mnpctech.3dpixelnet.com/p...ibrary/hc4.jpg
Hmmmm.... debating about the factory feet
http://www.mnpctech.3dpixelnet.com/p...ibrary/hc6.jpg
Sorry, these factory feet MUST GO!.... more on that later
http://www.mnpctech.3dpixelnet.com/p...ibrary/hc5.jpg
I just wanted to see how our rad grill looked on the Obsidian, thats all
Updated 1/02/10
We finished the HC logo inspired window frame today. This was made from 1/8" thick aluminum.
http://www.mnpctech.3dpixelnet.com/p...rary/hc9z4.jpg
http://www.mnpctech.3dpixelnet.com/p...rary/hc9z5.jpg
http://www.mnpctech.3dpixelnet.com/p...rary/hc9z6.jpg
http://www.mnpctech.3dpixelnet.com/p...rary/hc9z7.jpg
Update 1/03/10
We finished the custom HC logo 3x140mm rad grill last night.. each of the grill are 360 degree adjustable...just for fun, cause we can :biggrin:
http://www.mnpctech.3dpixelnet.com/p...rary/hc9z8.jpg
http://www.mnpctech.3dpixelnet.com/p...rary/hc9z9.jpg
http://www.mnpctech.3dpixelnet.com/p...ary/hc9z9a.jpg
http://www.mnpctech.3dpixelnet.com/p...ary/hc9z9b.jpg
The Obsidian feet were given fresh coat of HoK paint as well.
http://www.mnpctech.3dpixelnet.com/p.../hc9z9z9l2.jpg
http://www.mnpctech.3dpixelnet.com/p.../hc9z9z9m2.jpg
The plastic 5.25 bay Power / Reset Switch plate
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9n.jpg
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9o.jpg
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9p.jpg
The bezel is finished. I'm waiting for the sun to come back, so I can go outside and take photos of the paint.
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9s.jpg
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9t.jpg
The Hot Swappable bay
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9u.jpg
The 420 rad grill frame painted Candy Apple Red
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9k.jpg
Update March 10th
http://www.mnpctech.3dpixelnet.com/p.../hc9z9z9z2.jpg
Installed 140mm Xigmatek XLF-F1455 140mm cooling fan (1000 RPM, 63.5 CFM @ 16 dBA) cooling fan and billet "Hardware Canucks" grill mounted on the Hot Swappable bay.
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9y.jpg
http://www.mnpctech.3dpixelnet.com/p...y/hc9z9z9z.jpg
Ok, back to more seXay images...
To mount my Rad Grill / Case / Fan / Radiator sandwich, I use our M3 x 35mm length socket head stainless steel screws. These fit perfectly without the worry of piercing your radiator fins.
http://www.mnpctech.com/M4_30mm_silv...g_mnpctech.jpg
http://www.mnpctech.3dpixelnet.com/p...d_install1.jpg
http://www.mnpctech.3dpixelnet.com/p...d_install2.jpg
http://www.mnpctech.3dpixelnet.com/p...d_install3.jpg
http://www.mnpctech.3dpixelnet.com/p...d_install4.jpg
http://www.mnpctech.3dpixelnet.com/p...d_install5.jpg
http://www.mnpctech.3dpixelnet.com/p...d_install6.jpg
Yep, it's the Hardware Canucks logo window frame.
http://www.mnpctech.3dpixelnet.com/p.../hcwindow1.jpg
http://www.mnpctech.3dpixelnet.com/p.../hcwindow2.jpg
recalled we had bought frosted vinyl for another project window. This is the film resellers use for
http://www.mnpctech.3dpixelnet.com/p...dowETCHED1.jpg
http://www.mnpctech.3dpixelnet.com/p...dowETCHED2.jpg
http://www.mnpctech.3dpixelnet.com/p...dowETCHED3.jpg
http://www.mnpctech.3dpixelnet.com/p...dowETCHED4.jpg
http://www.mnpctech.3dpixelnet.com/p...dowETCHED5.jpg
http://www.mnpctech.3dpixelnet.com/p...mnpctech9a.jpg
http://www.mnpctech.3dpixelnet.com/p....mnpctech1.jpg
http://www.mnpctech.3dpixelnet.com/p....mnpctech2.jpg
http://www.mnpctech.3dpixelnet.com/p....mnpctech9.jpg
http://www.mnpctech.3dpixelnet.com/p....mnpctech7.jpg
Some photos I took before the case outdoors before it was shipped to HWC.
http://www.mnpctech.3dpixelnet.com/p...ian_paint3.jpg
http://www.mnpctech.3dpixelnet.com/p...ian_paint4.jpg
http://www.mnpctech.3dpixelnet.com/p...ian_paint5.jpg
Supergrover January 24, 2010 11:49 AM
Awesome!
Subscribed.
MarkOne January 24, 2010 11:53 AM
Something that will make peoples who don't order the NCIX deal regret it .
AmuseMe January 24, 2010 11:54 AM
Really Bill?! A case for us? Who gets it, and how many other forums are you doing?
Sushi Warrior January 24, 2010 11:56 AM
Awesome! Who said US/Canadian relations were bad?
HaDeS January 24, 2010 11:56 AM
thats my dream case right there... suscribed! :thumb:
Pelt January 24, 2010 12:00 PM
This is going to be an epic thread.
Lamb January 24, 2010 12:03 PM
How much for it? :P
Zero82z January 24, 2010 12:09 PM
Okay, you definitely have my attention :thumb:.
Polygon January 24, 2010 12:25 PM
This is awesome, didn't know you would do a case just for Hardware Canucks. Also, this seems to be the enthusiast favorite around here (mostly) so you sure have done your research!
