  #31 (permalink)
Old October 13, 2007, 01:35 PM
BALISTX's Avatar
When I had the PSU out of the case, I tested the main ATX connection with a multimeter and the power was coming through on all the connection. I'll try this tonight. I'll Jump starting the PSU tonight with a fan connected to the molex connection.
Heatware
HWBOT
  #32 (permalink)
Old October 13, 2007, 01:40 PM
3.0charlie's Avatar
FYI, it may take more than 1 fan though.
Hydro-Quebec is salivating...
  #33 (permalink)
Old October 13, 2007, 01:48 PM
BALISTX's Avatar
I have an old CD-RW I can try.
Heatware
HWBOT
  #34 (permalink)
Old October 14, 2007, 08:59 AM
BALISTX's Avatar
I tried jumpstarting the PSU and still nothing coming from the molex connectors. I tried hooking up 3 fans and CD-RW drive and nothing.
Heatware
HWBOT
  #35 (permalink)
Old October 14, 2007, 09:59 AM
omgwtf's Avatar
So it's still not working? :(
I had some problems with my ocz power supply at my first install...it seems that a pin was broken and I had to use the other cable, try going with your sistem at a service..for 40 bucks they'll fix it if it has something..
Memento mori
  #36 (permalink)
Old October 14, 2007, 10:03 AM
BALISTX's Avatar
i'm waiting to hear back from NCIX.
Heatware
HWBOT
  #37 (permalink)
Old October 14, 2007, 10:13 AM
Supergrover's Avatar
RMA time
Damn that sucks BALISTX, have you tried a different PSU yet?
Did it take anything with it when it died?
R.I.P.
  #38 (permalink)
Old October 14, 2007, 10:23 AM
omgwtf's Avatar
I'll consider myself lucky that I didn't need to rma anything...thank you God :)
Memento mori
  #39 (permalink)
Old October 14, 2007, 10:48 AM
If you are into overclocking for awhile then you will, pure fact unless you're very very lucky and if you are then go buy a lottery ticket win big and buy the badest rig you can.
Only to RMA it.
R.I.P.
  #40 (permalink)
Old October 14, 2007, 10:54 AM
3.0charlie's Avatar
You've done all that could; time to rma. I hope that the other components were not damaged though.
I hate PSUs.
Project: P190 MpG Case Mods, Worklog & Gallery 44 May 7, 2008 08:47 PM
My First Ever Water Cooling Project zlojack Water Cooling 37 February 6, 2008 09:10 AM
Large project James_8970 HTPC Systems & Software 6 January 9, 2008 10:44 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
BALISTX'S 939 Project BALISTX Case Mods, Worklog & Gallery 55 September 26, 2007 04:23 AM
