Old January 12, 2010, 03:58 PM
Default Water cooled tech station build
Here's my home made build I did using an old case that was kicking around the shop. This is my main PC that folds when idle. The idea came from knowing the challenges of working on water cooling systems in a tight closed case and being a tech I was aiming for something easy to work on. Also I wanted something where I could easily view the hardware that I spend my $$ on
This was a budget build and some parts were recycled from my old system (CPU, rad, pump, and PSU).
E8500(es) @ 4.275GHz - Rampage Extreme - 2x XFX 4770 - 2X2GB Corsair Dominator 12800 - 2X500GB
Old January 12, 2010, 04:03 PM
3.0charlie's Avatar
That's a very nice setup you got there. Wc'ing using HSPC-style benches is always difficult with the rad location.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old January 12, 2010, 04:17 PM
sswilson's Avatar
Very sweet looking build!!!! What manner of paint did you use (Looks like somebody might have access to a paint booth.... ;) ).
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old January 12, 2010, 04:18 PM
MarkOne's Avatar
Very nice setup, if you allow me I'm gone build one base on you's will be funny, because I have also a rampage extreme
Old January 12, 2010, 04:20 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Looks great man, hell of alot nicer than mine heh
Old January 12, 2010, 04:22 PM
gingerbee's Avatar
very clean just the way i like it cool build man/gal
Old January 12, 2010, 04:24 PM
martin_metal_88's Avatar
It can be budget and some recycled but is freaking awesome! looking so nice for a home built tech station! If only I was capable of holding a hammer:)
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old January 12, 2010, 04:29 PM
sswilson's Avatar
Holding's not usually the problem, it's once the swinging part starts that things can go wonky.... :)
But yeah, I second your thoughts.... that's an amazing job especially considering a good portion of it came from an old case.
Old January 12, 2010, 04:30 PM
lowfat's Avatar
Lookin good
1. Xeon ES 4c/8t * X79-UD3 * HD7970 * 16GB DDR3 * 64GB Crucial M4 * 80GB ioXtreme * 1000W Silverstone
2: 27" iMac * i5 750 * 80GB X25-M G2 * 4GB DDR3 *
3: 2600k * P8P67 Pro * GTX460 * 16GB DDR3 * 40GB X25-V * RR2314 * (2) Sans Digital TR8M-B * 46TB * 1050W Enermax
Old January 12, 2010, 04:53 PM
Spray cans and patience, multiple light layers lol
lemonlime's new and improved F@H tech station lemonlime HardwareCanucks F@H Team 37 December 22, 2009 05:34 PM
Build Log: CPINTS Cool Practical IKIKUINTHENUTZized NAVIG Tech Station IKIKUINTHENUTZ Case Mods, Worklog & Gallery 20 September 19, 2009 01:30 PM
Water Cooled Tech Station chibi_man Case Mods, Worklog & Gallery 88 July 31, 2008 05:34 PM
HighSpeed PC 'Top Deck' Tech Station review by TechPowerUp! Babrbarossa Reviews & Articles from the Web 0 May 23, 2007 10:44 AM
