  #51 (permalink)
Old June 18, 2010, 09:02 PM
AmuseMe's Avatar
Default Props to my bro Martin
I got ahold of a good friend and family member of mine to make me some new cables. I think he does the best sleeving bar-none. This is, without a doubt, the perfect sleeve: (these are my cable btw)
24pin (20white, 4grey)
6pins and 8pin
These are rock solid, and are not coming loose. They are 100% hand made. He cuts his own wire (used white wire for white sleeve, grey wire for grey sleeve [he does this for all colors), crimps the connectors, and sleeves everything super tight and perfect - doesnt get better then this. MDPC-X Sleeve, and ATX pins. THANKS MARTIN!
  #52 (permalink)
Old June 18, 2010, 09:12 PM
Liu Kang's Avatar
Those are some sweet shots, great sleeving too...
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
  #53 (permalink)
Old February 18, 2011, 09:26 PM
AmuseMe's Avatar
Yea, an update. I wont go in to detail about how many times I took this TJ07 apart and redid it, ill just let some pictures do the talk - more like a hint.
- Cables from gray and white extensions to full length Black/ White/ Color-X. No compromise!
Ill start with the 24pin:
And the reason behind the name "Total Eclipse"
... More to come
  #54 (permalink)
Old February 18, 2011, 09:30 PM
that is really nice man. i wouldnt have 1/100th of the patience you got there. hats off!
  #55 (permalink)
Old February 19, 2011, 07:19 AM
Toyoracer's Avatar
Hi AmuseMe, nice to see you back at this build, I know how life gets in the way you are a very busy young man.
The splash of color-X is perfect accent. Looking forward to see you complete this build.
Laughing, Loving still Living
  #56 (permalink)
Old February 20, 2011, 06:22 PM
AmuseMe's Avatar
Thanks _dangtx_ and Toyoracer
My girlfriend had to move home due to some family medical issues (nothing too severe), so I have a lot more free time, though, I would trade this entire computer to have her move back here again.
Anyways. I made more progress today - clean 5870 caps, and clean motherboard caps No one likes that gross blue paint anyways. Pictures to follow tonight.
  #57 (permalink)
Old February 20, 2011, 10:38 PM
AmuseMe's Avatar
Caps are clean!
  #58 (permalink)
Old February 20, 2011, 10:43 PM
What do you clean the caps with? An abrasive sponge or steel wool or something?
  #59 (permalink)
Old February 21, 2011, 09:40 AM
AmuseMe's Avatar
Some people use pure acetone, but I wanted to make mine look dull/ matte in color. I used acetone + 1500 gritt sand paper and lightly rubbed them.
  #60 (permalink)
Old February 21, 2011, 07:01 PM
AmuseMe's Avatar
Put some electrical tape over my Corsair logos (tape will come off easy without removing the stock sticker :D)
Cables going down under the midplate:
HeatKiller!:
Two random shots:
Those PCI-E cables might need some work
Spire TherMax Eclipse - Keeping the Cool in Style Soultribunal Press Releases & Tech News 2 December 15, 2009 08:30 PM
OCZ Eclipse impruv Peripherals 3 December 1, 2009 11:52 AM
[FS] Saitek Eclipse KB, Belkin N1 Router ottoyu34 Buy/Sell & Trade 0 December 16, 2008 07:55 PM
Razer Lycosa vs Saitek Eclipse II (2) Kassela Peripherals 22 August 11, 2008 08:15 PM
