  #51 (permalink)
Old December 14, 2007, 12:10 AM
Patriote's Avatar
DA BIG UPDATE! December 10-07 :D
*Firstly, excuse the delay guys! Things have changed quite a lot since i decided to start that build.*
Hey my friends! Guess what? The computer is completed and the RIG is running hard!
I'll let the pics speak for them self!
You guys remember i had tried the QX6800ES On my P5B Deluxe because it would act really freaking weird on my EVGA 680I A1? I was getting high 70c degrees for 3.4Ghz with my Tuniq on my P5B Deluxe? And then i posted a few results of that CPU running under H2O on my EVGA 680I A1? The shots close to 4Ghz and 19k in 3DMark06?
These shots. Well this is what the RIG looked like when it was running those results. I didn't had much more time to test the RIG at that time so i didn't worked in 4Ghz stable. But i will now ;)
Well, since i had received my MCW30 from NCIX.com (Along with Crysis :D) I decided i should tear the system apart and rebuild the CPU\NB loop to include the SB as well. And while I'm at it, why not loop the GPUs? :D
Tearing the system apart and cleaning the parts.
Once all parts were cleaned and the mobo too, i started hooking the block. Starting with the SB since i wasn't sure of how i would of mounted it since one of the thumbnut would come right in the GPU1 way... so i had to use smaller screws with a nut instead of the original mounting set-up.
Then i hooked all other blocks...
Pretty tight but it fits! I had to hook a small piece of electrical tape on the card just in case the screw would come in contact with the card. I really don't want to short another 8800GTX to death.
I decided i would loop the CPU loop first, boot with my good ol' 7800GTX, see if all is fine and then i would loop the GPU loop.
CPU\NB\SB looped!
Filling and bleeding.
Now, once i was done, i powered the computer, tweaked this and that and finally, after 30 mins, i had the comp running with that new CPU\NB\SB loop but only with my 7800GTX. So i went ahead and started hooking the 8800GTXs with their EK FC Blocks and looping it all!
Here is the result...
Here you can see my Becnh table with my P5B Deluxe, Q6600 G0, 7800GTX etc... Which will be used as my Crunching Rig :)
I hope you guys enjoyed the HUGE worklog! Lots of work, Money and time involved into it! But it's finally completed! :yepp:
Thanks for all the support\comments\suggestions etc... Guys! What a blast this build was!
I might post some more Overclocking results laster in the week! So far, 3.95Ghz\ 4GB @ 1000Mhz and 2x8800GTX 626Mhz\2000Mhz are probably my 24\7 clocks! That's 19k in 3DMark06!
Thanks again Guys and enjoy the pics!
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
  #52 (permalink)
Old December 14, 2007, 02:19 PM
magictorch's Avatar
Default wow
Nice score!!!! that must be the record for the forum?
  #53 (permalink)
Old December 14, 2007, 02:43 PM
llama_egg's Avatar
I...hate...you...so...much! It's just so...sexy. That case really gives you alot of head room for playing doesn't it! And of course now that your done with that build your giving it to me to start something else.... *shifty eyes*
Haha, anywho, very well done! *thumbs up*
  #54 (permalink)
Old December 14, 2007, 07:27 PM
Patriote's Avatar
Heh Thanks guys! Not sure if the 3.95Ghz is a record for HWC.com but anyway
• - Noctua NH-D14
  #55 (permalink)
Old December 14, 2007, 07:37 PM
3.0charlie's Avatar
I think it is, I think it is.... that is one beautiful rig you have. You have put a lot of hours in it and it shows.
John
Hydro-Quebec is salivating...
  #56 (permalink)
Old December 15, 2007, 07:16 AM
magictorch's Avatar
Default prize
patriote should get a prize or "honorable mention" for hitting the forums top 3dmark and OC on a quad....
I wonder if people should get prizes or special mentions for getting high folding scores too based on duual and quadcores? might be an extra incentive.
  #57 (permalink)
Old December 15, 2007, 09:21 AM
Hillsdale's Avatar
Is that Cube case or what? it looks like a mix of both.
[Tagan Black Pearl] [XFX 780i Tri SLi Mobo] [(x2) EVGA 9800 GTX] [Intel Q6600 @ 3.2ghz (Water)] [Corsair 2gb DDR2-800] [(x2) Seagate 500GB HD] [Ultra X3 1000w Modular PSU]
  #58 (permalink)
Old December 15, 2007, 10:54 AM
llama_egg's Avatar
It's an U2-UFO, very nice looking cases, but cost an arm and a leg. Pretty much a giant cube, I love the idea of being able to have one side converted completely into hard drive space, I love the idea that with a bit of converting you can fit 12 easily in that thing, and have one PSU just power those. Mind you though, what the hell would I use 12 hard drives for >_>
  #59 (permalink)
Old December 15, 2007, 10:55 AM
Hillsdale's Avatar
pr0n.
  #60 (permalink)
Old December 15, 2007, 06:18 PM
Patriote's Avatar
Heh Thanks guys :) Really, i appreciated the kind words!
Heres a link of a quick vid i made of me playing Cod 2!
Video of MPC2 - Photobucket - Video and Image Hosting
PS: I know i forgot to set the game to "Yes" for a SLI set-up.
• - Noctua NH-D14
Project "Gettin' out of the Ghetto" biff Case Mods, Worklog & Gallery 89 December 5, 2009 04:08 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
"Reviewer Tryouts:" Logitech Cordless Desktop LX710 Review Scratch Member Reviews 9 November 22, 2007 10:17 PM
My up-coming project! It's called "XETM" Patriote Case Mods, Worklog & Gallery 23 September 25, 2007 09:50 PM
TweakTown reviews GeCube X1950 Pro Champion Edition with "TEC" cooling Supergrover Reviews & Articles from the Web 0 December 18, 2006 11:44 PM
