  #41 (permalink)
Old December 27, 2007, 08:37 PM
sswilson's Avatar
Cores are peaking at 44/40 under orthos which is pretty good considering that this E6600 takes 1.575 to get it up over 3400....... :)
  #42 (permalink)
Old December 27, 2007, 10:48 PM
3.0charlie's Avatar
And that is only the beginning: my E6400 did 3.6 w/1.55V water-cooled.... usually with water-cooling, the main roadblock is cooling the NB properly. Once that's done, the board becomes rock-stable.
Hydro-Quebec is salivating...
  #43 (permalink)
Old December 29, 2007, 11:12 AM
magictorch's Avatar
Default Nice temps
Those are impressive temperatures. I wonder what youd get with a quad. Bet your looking forward to folding with the 45nm chips.
  #44 (permalink)
Old December 29, 2007, 12:42 PM
sswilson's Avatar
I was looking forward to it, but I'm not willing to hold off until the 12M cache ones finally hit the street so I've got my eye on a used Q6600 that's posted some pretty impressive #'s.
Should know if I can get it in the new year. :)
  #45 (permalink)
Old January 5, 2008, 05:38 PM
sswilson's Avatar
Got my hands on that Q6600 I had my eyes on...... :)
3.9G after 30 minutes prime and there's more room where that came from :)
Doubt I'll want to run those temps 24/7, but not too shabby for a quad running @ 1.55V
  #46 (permalink)
Old January 5, 2008, 09:24 PM
3.0charlie's Avatar
Nice numbers! What's the VID on that golden sample? 1.2125V? My second Quad in my rig can reach 3.8GHz, same temps (64C, 1.525V). Just a tad too high for 24/7 ops. I have settled for 3.6, @ 1.45V.
Is yours under water too?
  #47 (permalink)
Old January 5, 2008, 09:28 PM
Prof. Dr. Silver's Avatar
That is a great Q6600! Good job man! Let us see what your benchies are like!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
  #48 (permalink)
Old January 5, 2008, 09:34 PM
magictorch's Avatar
Default another monster OC
It really is "action stations" in the forum at the moment. Massive OC's all over the place
Thats a hell of a chip.
  #49 (permalink)
Old January 5, 2008, 10:31 PM
sswilson's Avatar
Coretemp lists VID as 1.2750 box has batch L726A850.
This is sitting under the "still under construction" new WC build.
I'm currently running 2 VMs but haven't got FahMon working on the second one... I'm assuming it's working as all 4 cores are working and total workload is 96% (do I have to change the machine ID on the second VM or is that just if you're running two instances on the same "machine"?).
Temps with the VM are maxing out at 55c so I'm going to let it run overnight to see how it does. :)
I can boot into windows and run super-pi @ 4G+, but it's not prime stable so it would need to be bumped up to 1.6V and I'm not willing to push it that far. :)
  #50 (permalink)
Old January 5, 2008, 10:42 PM
3.0charlie's Avatar
That is a great sample! You will have a lot of fun playing around with it! 1.6V is not really pushing it for benching; as far as running 24/7 w/1.6V, that's a different story. 55C under load is very much acceptable.
For FAH, each VM is a stand-alone environment. No need to change the machine id.
CM 690 Side window Theblackmages Case Mods, Worklog & Gallery 6 February 2, 2008 09:28 PM
Looking for a P182 Window Side Panel IN CANADA Hillsdale Cases 10 December 15, 2007 08:09 PM
Window Appliqués BALISTX Cases 5 October 15, 2007 08:21 PM
Top mount radiator - what would I need? JayDee Water Cooling 22 July 17, 2007 06:21 AM
Panel mount connectors for PSU? MacJunky Power Supplies 0 May 18, 2007 05:12 PM
