  #21 (permalink)
Old September 26, 2007, 04:57 PM
3.0charlie's Avatar
Originally Posted by sswilson View Post
Yep, top mounted PSU, and unfortunately the 1/2 ID hose would probably kink if I tried to put a tight radius bend into it.
The more I think about it, the more I'm thinking of running the tubing straight down into the case through the plexi.
Yup, typical .5" tubing kinks with a rad smaller than 3". Below that Smartcoils are need. Then min. rad is 1.5" - but I wouldn't try that...
Running straight inside the case is the easiest, cleanest way to do it.
  #22 (permalink)
Old October 2, 2007, 09:03 AM
sswilson's Avatar
Sorry about the lack of an update... unfortunately there's nothing to add other than the fact that I got my second length of smartcoils yesterday.
Hopefully I'll have time to strip the case right down over the long weekend and then be able to start on the case mods.
  #23 (permalink)
Old October 6, 2007, 07:49 PM
sswilson's Avatar
Finally got some time to start this.....
Initial pics....
Starting point.... It's been pretty good to me.... :)
Stripped down to just the old WC gear
Ready to go under the knife...... :)
The last pic shows why I need to do a top window mod at the same time as the WC upgrade.... gotta get rid of those holes for the hoses & need to do something aobut the fan cut out as well.
So far things aren't going as planned.... the flush mount kit isn't working as I had hoped so it's off to Canadian Tire tommorrow for a pop rivet gun to make due with. (Wish I could find some real "peaning" rivets, but last time I asked the salesperson looked at me like I had two heads..... :) ).
  #24 (permalink)
Old October 7, 2007, 01:13 PM
sswilson's Avatar
Finally found a solution to the mess I made of the top window...... :)
I squared out the top hole, and smoothed out the edges with hand files.
Cut the window out (easiest tool without cracking is the small dremmel cutter), as well as cutting out the fan hole & drilling out the screw holes for the fan.
Had a hell of a time figuring out how I was going to mount the window.
Even once I had decided to use some brackets to secure it from the bottom I was trying to figure out how I was going to get the holes perfect for the pop rivets and still keep the brackets tight against the plexi......
After a couple of hours worth of head scratching the big light bulb came on and I finally decided on sticky velcro which not only allows me to easily mount the brackets tightly... it also allows me to install them "rough" for now and worry about making them pretty at a later date.
Window secured in place. Seems strong enough even with a few temporary brackets in place. Still will need to drill the holes for the WC tubing once I get the rad installed. (Protective film is still in place, so it looks like crap... :) ).
  #25 (permalink)
Old October 7, 2007, 02:20 PM
BALISTX's Avatar
Looking good. BTW what are those things your wife made on the cooling rack? They look good.
Heatware
HWBOT
  #26 (permalink)
Old October 7, 2007, 03:58 PM
sswilson's Avatar
Shortbread cookies with jam in the middle..... :)
With the big turkey dinner tomorrow, we're fighting over workspace upstairs, and it's already dark out so I can't work outside.... guess who wins the space war????? :)
  #27 (permalink)
Old October 7, 2007, 04:04 PM
BALISTX's Avatar
Nice.
Speaking of workspace I am fighting with my wife over that too. I showed my wife the Pudget Mineral Oil rig and she wants me to do that for the home theatre system. I think it would be cool and make a conversation piece. I'm gonna put the old XP 3000 Barton in.
Heatware
HWBOT
  #28 (permalink)
Old October 7, 2007, 05:49 PM
sswilson's Avatar
Proof of concept for my rad mounting plan. Seems more than strong enough, even with just the two mounting points per side.
The pump and res were the easiest step of this build so far..... :)
I absolutely love the mounting hardware that comes with the swiftech mini-res!!!! If a person can't find a way to mount this thing in their case, they aren't examining all of the possibilities.
  #29 (permalink)
Old October 7, 2007, 06:41 PM
Supergrover's Avatar
Nice Job sswilson!
I agree about the swiftech res.
R.I.P.
  #30 (permalink)
Old October 7, 2007, 06:50 PM
3.0charlie's Avatar
Me want cookies!
Those brackets will be more than enough to withstand the weight of the filled rad, for sure. Are they 2 or 4 brackets?
Hydro-Quebec is salivating...
CM 690 Side window Theblackmages Case Mods, Worklog & Gallery 6 February 2, 2008 09:28 PM
Looking for a P182 Window Side Panel IN CANADA Hillsdale Cases 10 December 15, 2007 08:09 PM
Window Appliqués BALISTX Cases 5 October 15, 2007 08:21 PM
Top mount radiator - what would I need? JayDee Water Cooling 22 July 17, 2007 06:21 AM
Panel mount connectors for PSU? MacJunky Power Supplies 0 May 18, 2007 05:12 PM
