  #71 (permalink)
Old February 8, 2010, 02:45 AM
HaDeS
Guest
Posts: n/a
That's not entirely true.. the Thermaltake Eureka home server case (150 bux or so) will support that board no problem. I 'had' 6 inches behind the video cards with a normal full sized mobo installed.
Thermaltake Eureka Aluminum Case: Introduction - Techgage
  #72 (permalink)
Old February 8, 2010, 06:30 AM
CMetaphor's Avatar
Sorry friend, I think you're thinking of SSI CEB, which does fit in the case as you can see here : Techgage Image - Thermaltake Eureka
However, these motherboards are SSI MEB, and are a full 4 inches taller Above the IO panel. As you can see from above image, there is no space about the IO panel because the PSU resides there. Nice try though! And a good find for all the e-atx/ceb users out there.
  #73 (permalink)
Old February 8, 2010, 08:00 AM
MarkOne's Avatar
here we go
I have this case, collecting dust under my bench in my garage, I take all the measurement, and the board of CM and DT fit right inside. I don't think I will ever do a such project So if someone need it for build a quad core I will more than happy to give it to him. Anyway he will finish with more dust. And for the interested one. you can fit 5 or 6 4x120 rad in the drive section, the case is split in half in the middle. And have a look at the kind of PSU ( not include ) you can throw at the bottom , the mother tray is fully removable, you just turn the handle 90 degree and pull it , quite useful. You can pass on with car on the motherboard tray. As server case it's a dinosaur, so it ill fit well with you CM
This case is very strong how many time I climb on it to reach thing on higher shelf, and I'm not quite a light weight guy , but it's at a cost. if you not MarkOne , you need 2 guy to put it on the bench full loaded
  #74 (permalink)
Old February 8, 2010, 11:36 AM
HaDeS
Guest
Posts: n/a
Ah right... i was wondering after I posted that if it would fit. It is a monster isn't it! It's a big bloody case though with a bit of modding it might fit?
  #75 (permalink)
Old February 9, 2010, 08:25 AM
Dead Things's Avatar
You're probably right on that one. My guess is that most EATX cases with a top-mounted PSU tray could be modded to accommodate a SSI-MEB mobo by transplanting the PSU into the 5 1/4 IN bays.
Current Project...
I ain't gonna work on DT's farm no more
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
  #76 (permalink)
Old February 9, 2010, 01:41 PM
HaDeS
Guest
Posts: n/a
I can tell you... there is a TON of room up there. With out a rom drive in there you could possibly get 2-3 PSU's back to back in there. Where do you live I have one collecting dust here at the moment.
  #77 (permalink)
Old February 10, 2010, 12:37 AM
dragoonxx's Avatar
is that an old P4P800?
  #78 (permalink)
Old February 10, 2010, 05:03 AM
MarkOne's Avatar
ya with a P4 EE under the fan
  #79 (permalink)
Old February 10, 2010, 09:43 AM
dragoonxx's Avatar
nice...one of the 3.0GHz ones? or one of the speedier puppies? but...that case doesnt seem to be THAT big, it doesn't dwarf the motherboard
  #80 (permalink)
Old February 10, 2010, 09:50 AM
CMetaphor's Avatar
How about going back OT? Surely you can talk about overpriced outdated processors in PM.
This is a build log.
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 12:12 PM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 07:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 09:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
Leadtek Winfast PX8800 Ultra Leviathan @ Tweaktown SKYMTL Reviews & Articles from the Web 0 October 24, 2007 08:23 PM
