Old December 16, 2009, 09:28 AM
steers's Avatar
Holy. Crap. You're really doing the 800D justice, my man. Bravo.
/subscribed
Old December 16, 2009, 10:10 AM
AmuseMe's Avatar
Originally Posted by chuggoz View Post
Thanks Surfer_2099,
I'm planning on plain distilled water as coolant with 2 colours of tubing, Black for the cpu and red for the video cards. As for colour of lights i'm going with red and white.
What are you using for a biocide?
Old December 16, 2009, 07:24 PM
chuggoz's Avatar
From what I gather the Primochill Primoflex Pro LRT tubing has some kind of biocide in it... I've used straight dWater in the past with no problems. What kind of biocide would you recommend?
HOLY smokes these are loud!! thank god for fan controllers
Almost ready to start putting in the remainder of the red pipe..
Something to take note if your using velociraptors and want to put them in the obsidian's hot swap bays your out of luck. The power and sata connectors DO NOT line up they are slightly different then a standard drive... ARGH. I almost had to scrap using them in the build, than found a very tight spot in the front thats just the right size for 2 drives.
Old December 16, 2009, 07:39 PM
AmuseMe's Avatar
If you can, grab one BitsPower TRUE Silver fitting. Silver is a great biocide by itself. Just make sure you are not mixing metals, ie, copper, aluminum, etc. etc. However, most blocks are all copper, so you should be safe. And if you havn't had problems in the past than great Although, I myself would still grab a silver fitting, or two.
Old December 16, 2009, 09:43 PM
Iamcanadian7's Avatar
They made a second revision of the Velociraptor with connections that do line up. I've only seen a few of them though.
Very nice looking build, can't wait to see it completed!
Old December 25, 2009, 02:00 AM
chuggoz's Avatar
Both Loops are rolling.. zero leaks
Top display is cpu+mobo water temp bottom is video cards
Old December 25, 2009, 02:01 AM
Infiniti's Avatar
Full build pictures now!
Old December 26, 2009, 01:23 AM
chuggoz's Avatar
Went with the Lamptron 5 Channel Fan Controller Military Switch. Right now only 6 channels are being used the top bank is for the top 3 120mm fans and the bottom bank is for the bottom 3 120mm fans. One nice feature with these is when the switch is set to high the LED goes red when set to medium it is blue.
  #19 (permalink)
Old December 30, 2009, 12:47 AM
r11's Avatar
r11 r11 is offline
This is an excellent build! I really appreciate the pics.
  #20 (permalink)
Old December 30, 2009, 09:11 AM
misterlarry's Avatar
Gorro looks like quite the machine. Nice work!
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Project: i7 Lpfan4ever Case Mods, Worklog & Gallery 31 October 6, 2009 09:47 PM
first WC project Shadowmeph Case Mods, Worklog & Gallery 4 July 6, 2009 11:12 AM
Project: All Right S_G Case Mods, Worklog & Gallery 37 February 18, 2009 07:53 PM
Project: A+ Cardboard box with DSL Case Mods, Worklog & Gallery 33 April 14, 2008 08:40 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
