Old December 13, 2009, 10:44 PM
MonsterSound's Avatar
Verrry good Job! The wood panels are a nice touch too.
Thx for posting and I look forward to seeing the finished project.
btw, I buy most of my cables and adapters at MonoPrice.com because of their low prices and cheap shipping from the US.
HDMI right angle adapter $3.79
HDMI 90 angle adapter $3.79
Power Cord Right-Angle 6ft. $2.04
At Best Direct: $6.02 HDMI 90 angle adapter ($7.48 at NCIX)
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old December 13, 2009, 10:58 PM
HaDeS
Guest
Posts: n/a
Originally Posted by Varroa View Post
what hole thing? Do you mean the HDD rack? It supports the Blueray drive and the SSD.
As for cutting the back of my home entertainment center in the bedroom, that wouldn't help because it is butted up against the wall and I can't move it out any.
Yep the hdd rack... you can't cut it down more? It's good if you can give it a bit more air flow. I lost 2 mobo's due to poor air flow. I fixed it by putting a few hundred holes in the top of the case.
Old December 13, 2009, 11:58 PM
Caldezar's Avatar
Nice job! The wood case should also keep the noise level down quite a bit as well. As for your cabling, the 90 degree HDMI adapters Toyo posted are a great option for you. There's also power cables available with flattened female ends for the same purpose. Although I can't for the life of me seem to find a link to one. How much have space do you have to work with at the back?
And I'm interested to see a pic of this thing complete and installed in your entertainment unit.
Old December 14, 2009, 05:47 AM
Varroa's Avatar
Thanks for the ideas guys. I'll keep those in mind. I don't really need the short HDMI cables anymore since I am using a WD LiveTV in my bedroom and this is running in my entertainment center downstairs which has a bit more room. I am going to try and cut down the metal lid this week or next (when I find time) and that should be the last thing.
The HDD case is support on both sides so the only cutting I could do would be to remove the bottom HDD mounts. That may provide some more space and air flow.
Pics once it is done!
GAMER: Win10 Pro x64, I7 3770K (4.7Ghz) (corsair H110i), Asus P8Z77-V Pro, EVGA GTX 1080 FTW, Gskill 2 x 8 GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Crucial M500 480 GB SSD, Mx 500 SSD, HX750W, Sound blaster Z, & Fractal Design Arc MIDI R2
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old August 28, 2010, 12:42 PM
Varroa's Avatar
Default Finally Finished!
Finally got around to finishing the lid. I also added a 5450 so I could have hardware decoding support in VLC media player AND to give the machine a little more power. Here are the finished pics:
Project "Gettin' out of the Ghetto" biff Case Mods, Worklog & Gallery 89 December 5, 2009 04:08 PM
Project "Unus Multorum" - Rebuilding the Rebuild ChuckleBrother Case Mods, Worklog & Gallery 12 August 10, 2009 08:43 AM
Project "HAF-EXTREME" Wall86 Case Mods, Worklog & Gallery 8 August 1, 2009 01:58 AM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 01:08 AM
My up-coming project! It's called "XETM" Patriote Case Mods, Worklog & Gallery 23 September 25, 2007 09:50 PM
