OK, FINALLY something to report.
the case has GONE no where, shes on stand by for the time being. However I did get to finish some other small projects. So enjoy.
For starters, I moved my desk around and I began to plan on building some small units to help make life easier and things look nicer. First off, this is a stand I made up in about an hour. Purpose... simply a stand for my stereo receiver. gives me more room on my desk.
Seeing how I bought a new set of speakers, I needed to lift my monitors up higher due to the hight on the front speaker.
And Finally. This was a spur of the moment thing. For awhile i was in need of a good place to work on small parts... Electrical, mechanical, etc etc.... more or less a spot to work on my computer and such. I just wanted something simple, can store more of my crap, and can fit beside my desk.
Honestly... My classes ended at 1pm today. Had to get gas since my car was running on fumes. Just because the petro was across the street from the home depot I HAD TO GO INSIDE. and from that I ended up buying the materials I needed... cost my $31.27 for everything. and 4 hours later... VOILA (to please the French here) the bench was made. Now I'm waiting for the stain to dry so I can take it out of the garage.
