  #41 (permalink)
Old October 12, 2007, 10:08 AM
chibi_man's Avatar
Well, I have had a MAJOR design flaw. Because of my new board the optical drives are to far away. getting longer cable would be a quick fix. however I am causing a loss in performance if I do. So this means the fallowing changes will most likely take place.
the original design for the drive placement is going out the window.
I will be having one DVD-RW in SATA. the drive will be located several inches below the current location. the floppy drive will be located inside the case itself, so it will not be accessible outside the case. the floppy is only used in special cases so theres no reason for me to modify a new slot for it.
Diamond plate will still be used in the front, only I am changing how it mounts... I plan on having it a glossy black so it will work well with the polished aluminum around the corners and sides. the Arctic fan I had on the other aluminum plate will also be used but it shall be located a few inches higher. so near around the center.
I maybe missing some other details but surely I'll explain them as I go about it. the build pace is going to slow down so I can spend more attention to the small details.
_____________________________________
If you can't beat it... SMASH IT!!!
  #42 (permalink)
Old October 12, 2007, 10:51 AM
chibi_man's Avatar
Ok i'm officially and idiot. making all these changes will result in me being able to use my IDE optical drives. seems I need to do some more thinking. Ignore most of what I wrote...lol
  #43 (permalink)
Old October 15, 2007, 09:53 AM
chibi_man's Avatar
I got bored in class and decided to draw some concept ideas since I am going to be modifying the front of the case. Pick and nick at them. suggestions are wanted at this time.
Idea number 1
Idea number 2 and 3
Idea number 4
this is a concept for around the front fan.
  #44 (permalink)
Old October 15, 2007, 10:47 AM
Apollo4g's Avatar
Great work!
I see you didnt have it all planed out when you started, just thinking and making up ideas as you go along?
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
  #45 (permalink)
Old October 15, 2007, 01:13 PM
chibi_man's Avatar
oh I had a full plan with CAD drawings. It was the minor details that screwed me.
  #46 (permalink)
Old October 16, 2007, 07:46 PM
chibi_man's Avatar
Made the adjustments for the new board.
A test fit was in order. And as you can see my 18in IDE cable is a little short.
Here is another mcguyver moment for you.
Working on a new idea for the front.
And the drives fit well.
  #47 (permalink)
Old October 17, 2007, 11:49 PM
qwerty's Avatar
Interesting project you have going there...looking forward to more news....
  #48 (permalink)
Old October 17, 2007, 11:57 PM
sswilson's Avatar
Love the first picture!!!
I usually don't get the mallet out until after a particular piece of hardware starts P###ing me off, not before........ :)
This is really turning into an interesting project (not that it wasn't at the start), I'm really looking forward to seeing the finished product.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
  #49 (permalink)
Old October 18, 2007, 01:04 AM
I'm assuming this isn't a LAN computer ;)
  #50 (permalink)
Old October 18, 2007, 08:39 AM
chibi_man's Avatar
Thanks, good feed back is given me awesome motivation. The mallet is a very fun tool... but thats my small mallet for small chisel work such as the notch I had to cut out. just wait, i'll show you my homemade BRUTE of a mallet.
And yes this will be a LAN machine... I built this one with the intent of making it portable, not like my last machine which needed two people to move it around my room.
Heres some more pics.
Oh, if you remember I was having an issue with IDE length. and I was considering switching everything to SATA or just simple modifying the case. Well SATA went out the window. I never had any big excuse why I would want to switch to it. IDE can come in the length I want however it has a performance problem... well I've come to the conclusion it's not a big deal to me.. I'm patient enough.
However I did try and see what I could do about changing the case. first I thought about changing the drive location. But that conflicts with my HDD's and my supports I built for the drives are well... ALL most indestructible. I built and installed them TOO DAMN WELL. so forget that. Then there was the option of changing the position of the board itself. well before I got started on that I mapped out it's location... and as you can see... I STILL NEED LONGER CABLE... oh well, she will still look awesome.
Fan controller has it's new home.
And now the front fan and it's officially glued to the case.
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 02:59 AM
Potential Warning Regarding HD3870X2 Cooler Compatibility SKYMTL Video Cards 8 April 25, 2009 08:56 AM
Scythe Ninja Rev B. for those considering it - lots of pics 56k warning! low351 Air Cooling 17 March 28, 2008 08:28 PM
Dry Ice [Warning 56k] CanadaRox Case Mods, Worklog & Gallery 27 March 14, 2008 09:51 PM
Nvidia driver 158.45 overclock warning ragenrok Overclocking, Tweaking and Benchmarking 7 June 17, 2007 07:49 PM
