  #31 (permalink)
Old September 28, 2007, 09:43 AM
chibi_man's Avatar
been making a last minute decision on the internal components... think i'm going to go 939... only if I can find an AGP version
_____________________________________
If you can't beat it... SMASH IT!!!
  #32 (permalink)
Old September 28, 2007, 10:27 AM
chibi_man's Avatar
Sweet deals, I found one and found a CPU... and no other upgrades required.
  #33 (permalink)
Old October 2, 2007, 06:19 AM
chibi_man's Avatar
OK... small update. I have currently have an ASRock 939Dual-SATA2 motherboard coming to me and I have an AMD Opteron 165 on order. So this means the box is going to have a mean machine under the hood.
I decided to add some curves and some shape to the open areas. A lot more work to go on it, but you can see the shape coming slowly.
  #34 (permalink)
Old October 3, 2007, 04:39 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Cool project!
  #35 (permalink)
Old October 3, 2007, 04:59 PM
your crazy!
And by the way you CAN paint the rad without any issue in regards to heat loss. Just don't cake it on.
  #36 (permalink)
Old October 3, 2007, 05:22 PM
BALISTX's Avatar
Originally Posted by enaberif View Post
your crazy!
I use to work in a rad repair shop and we use to repaint the rads. You can paint them just do one or tow light coats, enough to cover the area. I personally like a matte black. Just use a high heat paint like an engine paint.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #37 (permalink)
Old October 3, 2007, 05:50 PM
chibi_man's Avatar
Thanks
Yea, it was making me think twice for some time. Most likely it will get painted.
I have my New(by new I mean used) motherboard on the way. The ASRock 939Dual-SATA2. bought it off a fellow canuck "Soccerdood". Kind enough to give me a killer deal.
I Just ordered my new Processor to "AMD Opteron 165"
At the moment i'm debating on Fan Controllers. Price is a factor. currently it's the Sunbeam Chromatic Windmill. if you have a better suggestion, well you better hurry.
Oh, and I've decided not to use the chicken wire. I think it's BUTT ugly. I'll be experimenting with it soon enough.
  #38 (permalink)
Old October 5, 2007, 07:21 AM
chibi_man's Avatar
UPDATE!!!
Test fit for the fans behind the heater core
all four installed.
This is going to be the front plate.
Molding around the drives. I need this to make it fit nicely. the diamond plate is not to friendly to flat fits.
and finally some more work with the plaster of paris
  #39 (permalink)
Old October 6, 2007, 10:08 AM
kcksteve's Avatar
if i was you i would put the chicken wire in between the metal sheet u cut holes in and the fan, it might look nicer. Looking great
  #40 (permalink)
Old October 8, 2007, 08:54 PM
chibi_man's Avatar
Had the same thought after I finished that...
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 02:59 AM
Potential Warning Regarding HD3870X2 Cooler Compatibility SKYMTL Video Cards 8 April 25, 2009 08:56 AM
Scythe Ninja Rev B. for those considering it - lots of pics 56k warning! low351 Air Cooling 17 March 28, 2008 08:28 PM
Dry Ice [Warning 56k] CanadaRox Case Mods, Worklog & Gallery 27 March 14, 2008 09:51 PM
Nvidia driver 158.45 overclock warning ragenrok Overclocking, Tweaking and Benchmarking 7 June 17, 2007 07:49 PM
