  #21 (permalink)
Old September 26, 2007, 10:23 AM
3.0charlie's Avatar
Use a fillport for a clean look? http://www.ncix.com/products/index.p...minorcatid=226
  #22 (permalink)
Old September 26, 2007, 11:47 AM
chibi_man's Avatar
why spend 15$ plus shipping when i can spend 4$ at crappy tire or Home Depot.
_____________________________________
If you can't beat it... SMASH IT!!!
  #23 (permalink)
Old September 27, 2007, 08:21 AM
chibi_man's Avatar
Well I went out and bought some supplies last night.
Paint, Tubing, Wire Cover, and Wire meshing.
I figure the wire meshing would be perfect as grill material.
Heres the supplies
OK, heres the experimental grill.. PLEASE give me your thoughts. Note* i wana paint it black and thinking of having it side ways so it looks more like a diamond pattern.
  #24 (permalink)
Old September 27, 2007, 02:53 PM
3.0charlie's Avatar
Right now, it looks like too much to chicken wire. Put it sideways to ressemble a diamond pattern and paint it black, like you stated. Then we'll see how it really looks like. Will you paint the heater core black too?
  #25 (permalink)
Old September 27, 2007, 09:26 PM
chibi_man's Avatar
Sadly, thats the smallest quantity of chicken wire I could get. I painted the wire black and it looks pretty good... I don't think I'll put it sideways.
I like your idea of painting the heater core. It never really crossed my mind. but then again I don't really want to do that because the paint will act like an isolator and will prevent the core from removing the heat as efficient.
  #26 (permalink)
Old September 27, 2007, 10:27 PM
chibi_man's Avatar
Well I have fixed my fill port problem.
Decided to fill her up and do a second 24hr leak test... better make sure.
  #27 (permalink)
Old September 28, 2007, 05:47 AM
3.0charlie's Avatar
I'm sure there are paints that are made for heater cores - think about the automotive industry. I think it should not impact the heat transfer.
All I can say about that fillport... that's what I call heavy duty! Are the 2 top-most barbs leak-checked too?
John
  #28 (permalink)
Old September 28, 2007, 08:16 AM
chibi_man's Avatar
Yea I was thinking the same thing earlier. However theres 2 sides to that coin of thought. The paint may not only be used for looks but to take away some of the heat transfer from there rads. Make it easier for your vehicle to get up to it's optimal temperature. Just a theory of mine. Not saying thats how it is but you never know. Time to take a visit to crappy tire i guess.
Yea, that fill port is pretty heavy duty, but it's spare parts. So may as well use them up rather then spending more money. gives my case a more industrial look.
The 4 barbs on the top have been tested. I plugged all the barbs originally during my first test and pumped water to the top using a hand water pump. So i know it's leak proof there... However the coolant will not be filled to the top so my main concern is not there anyways.
Hopefully tonight I can finish up the cooling area so I can start some prep work. Projects going on longer then I wanted it to.
  #29 (permalink)
Old September 28, 2007, 08:36 AM
sswilson's Avatar
Heh... looks great!!!!
I still want to see a total weight when you're done though..... Looks like it's going to be something you could set out in public unattended and dare people to try to lug it away.......... :)
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
  #30 (permalink)
Old September 28, 2007, 09:40 AM
chibi_man's Avatar
if it weighs that much I will be considering that..lol
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 02:59 AM
Potential Warning Regarding HD3870X2 Cooler Compatibility SKYMTL Video Cards 8 April 25, 2009 08:56 AM
Scythe Ninja Rev B. for those considering it - lots of pics 56k warning! low351 Air Cooling 17 March 28, 2008 08:28 PM
Dry Ice [Warning 56k] CanadaRox Case Mods, Worklog & Gallery 27 March 14, 2008 09:51 PM
Nvidia driver 158.45 overclock warning ragenrok Overclocking, Tweaking and Benchmarking 7 June 17, 2007 07:49 PM
