Old September 23, 2007, 07:36 PM
chibi_man's Avatar
Shes indestructible not tall... lol
_____________________________________
If you can't beat it... SMASH IT!!!
Old September 24, 2007, 08:01 PM
chibi_man's Avatar
Thanks for moving my build into the worklog!
Ok heres a progress update.
This is going to be the support for the HDD shelving
Lookin fancy EH
now the shelves
Gotta love them apples
tomorrow I hope to have the front nearly complete.. that or the pump installed.
Old September 25, 2007, 08:30 PM
chibi_man's Avatar
Ok update time.
YOUR GOING TO LOVE THIS.
Check this out... I got creative.
Few bucks at your fellow Princess Auto gets you a nice LCD Mag light
This is all that in there.
Now solder the positive and negative leads.
Now the test... 5V from an old psu I had kicken around.
now to begin installation
Heres the really cool part... 1/4 acrylic
Now insert the acrylic into a PVC fitting
Do the same thing to another fitting. and glue together
Now drill and thread the Barbs
Thats going to be one SWEET reservoir
Old September 25, 2007, 08:53 PM
3.0charlie's Avatar
You're good, with lots of ideas. But why 5 barbs on the res?
Old September 25, 2007, 09:10 PM
chibi_man's Avatar
Thanks, I try... Engineering student. pays to be me.
The Heater core I have has 1 in and 4 out... so rather then messing around with the heater core to make 1 I used all 4 into the reservoir.
Heres some pics.
These are some test fit photos
You can get a glimsp of how things are set up.. you can see 2 of the lines into the res at the top.
Old September 25, 2007, 09:20 PM
3.0charlie's Avatar
That's one wicked res-core setup. Where's the fill point?
Old September 25, 2007, 09:25 PM
chibi_man's Avatar
Glad you asked.. I screwed up honestly... looks like the res might get a 6th barb or something else thats fancy.
Old September 25, 2007, 09:54 PM
BALISTX's Avatar
for a fill point you can just get an pvc elbow and then make a lid for it.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
  #19 (permalink)
Old September 25, 2007, 10:27 PM
chibi_man's Avatar
If your thinking of suggesting I use the elbow to attach to the reservoir it won't work since it is sealed off. however if thats not what your suggesting I could do something similar.
I think I am going to make this simple on me. I have a shut off valve with a 1/2 barb already on it... I'll put another barb on the reservoir and WALA I have a fill point. I just wish I payed attention to this sooner, I would of made it like my last set up where the fill port can be used as a drain as well. Damn I had to screw this one thing up.
  #20 (permalink)
Old September 26, 2007, 10:01 AM
chibi_man's Avatar
ok I have a better idea now. Rather then adding ANOTHER barb to the reservoir I'm going to put a standard threaded pipe to the reservoir, and elbow heading up right and then a pipe to the top of the case. Then I'll add a screw on cap.. WALLA
Guide : Sleeving a 3-pin fan! (56k Warning) Patriote Guides & How-to's 56 March 18, 2011 02:59 AM
Potential Warning Regarding HD3870X2 Cooler Compatibility SKYMTL Video Cards 8 April 25, 2009 08:56 AM
Scythe Ninja Rev B. for those considering it - lots of pics 56k warning! low351 Air Cooling 17 March 28, 2008 08:28 PM
Dry Ice [Warning 56k] CanadaRox Case Mods, Worklog & Gallery 27 March 14, 2008 09:51 PM
Nvidia driver 158.45 overclock warning ragenrok Overclocking, Tweaking and Benchmarking 7 June 17, 2007 07:49 PM
