Heya folks well a small update about my rig
well my reservoir "Typhoon 3" as give up on me starting to leek water so this weekend im about to install this new replacement reservoir i orderd
this one will last for years here's a sneek peek of the reservoir i think im going to mount this reservoir backward i mean by that ...
the motor pump housing will face the side window panel & the reservoir window
will face the back side panel i will have to get the side panel to the laser shop so like this on the we will be able to see the water with the side panel closed
and this will benifit to the air flow above the radiator only the motor pump housing will be in the way Vs the hole reservoir well hope you like it
So stay tuned more to come Keep On Modding
