Thermaltake Armor build Some new parts are in: Thermaltake Armor case (already had it) Asus M4At8-E MB AMD Phenom II X4 945 3.0Ghz am3 Swiftech cpu water block Swiftech 240mm and 120mm radiator Nvidia 8800 GT (already had it) D-Tek Fusion GFX OCZ RAM cooler Clearflex tubing 3 thermaltake 120mm blue fans Western Digital VelociRaptor 150GB 10,000RPM Windows 7 Now I just have to find the time to put it together, pics will be coming soon.... Below is what I currently have. |
cool:biggrin: I don't see any memory/psu... or are you using the ones from your old build? I would have recommended that you used the money you spent on WC to upgrade your gpu. Not sure how much WC stuff costs (since I've come to the conclusion that it's not suitable for my purposes, gaming on a value rig, since it is very low bang for buck), but if we put it at an estimate of $300, you can buy a very good $25 cpu cooler and a gtx275 with a $50 aftermarket cooler, or even just get a hd5850. Just my $0.02:thumb: Oh yea, you could also sell your current 8800, and maybe use the combined money to get a fresh psu, maybe modular :) |
i got an armor my self and i love it, but i just wish i could fit a 140.3pa somehow in it |
No pictures yet? :sad: I'll b waiting for this one. I wanted an Armor+ way back, but never did look into it. It will be nice to see how this turns out. |
