  #71 (permalink)
Old December 10, 2009, 09:52 PM
AmuseMe's Avatar
Originally Posted by kyle_L View Post
nice build, cant wait to see the finished pic's.
It is finished. Just need that camera fixed Oh, and my SSD needs to come back from its RMA to actually do anything...
  #72 (permalink)
Old December 29, 2009, 02:26 AM
r11's Avatar
r11 r11 is offline
Nice. I remember going through all those problems too! I recommend wrapping your lips around one end of the loop and sucking as hard as you can. Stick your tongue on the hose and plug the hole with your wet finger on the other end. You will pick up any of the big leaks right away and save yourself major headaches. Also, using distilled water is important if something does leak because you can just kill the power and hair dry the parts if you do leak.
For all you newbies: make sure you do a leak-test with your "jumpered" power supply
  #73 (permalink)
Old December 30, 2009, 11:20 AM
AmuseMe's Avatar
Yup, thats exactly how I did it. I just used a bobby pin and connected the green and black wires. If there was any sort of leak, I through down the Sham-WOW I than would keep all the case fans runnning on high for a few days to dry out.
Back to H2o Supergrover Water Cooling 20 August 22, 2009 10:17 AM
[FS] MCP 220 QP RAD CHEAP! Mike_E Buy/Sell & Trade 5 June 30, 2009 06:53 PM
H2O NO! Dr_BenD_over Case Mods, Worklog & Gallery 45 November 23, 2008 10:59 AM
BALISTX - Project Copperhead H2O BALISTX Case Mods, Worklog & Gallery 10 October 11, 2008 04:41 PM
Friendly's Upgrade Project Mr. Friendly Mobile Computing 0 April 16, 2008 12:50 PM
