  #41 (permalink)
Old November 22, 2009, 02:30 AM
ImmaPC's Avatar
Im guessing those are Scythe SFLEX G's on the 480 there? Its been awhile since this thread was conceived, and I'm too lazy to look back at the 1st page...
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #42 (permalink)
Old November 22, 2009, 08:11 AM
AmuseMe's Avatar
Yes they are I was going to use those Gentle Typhoons, but they are definitly to
much money (when buying eight).
  #43 (permalink)
Old November 22, 2009, 02:25 PM
AmuseMe's Avatar
Things to do as of November 22/ 09
  • Install BitsPower 45-degree Rotaries
  • Measure tubing and cut off as much excess as possible.
  • Install all compressions fitting/ attatch tubing
  • Flush/ leak test with distilled water several times
  • Dust everything out with some canned air
  • IF there are no leaks - wipe interrior/ exterior of case clean, polish blocks, fittings, etc.
  • Continue/ finish cable work
  • Overclock!
  #44 (permalink)
Old November 22, 2009, 05:03 PM
ImmaPC's Avatar
Wow, so much work to do. I'll be sure to set aside a weekend or two to get my loop done. Maybe over Christmas break? lol
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #45 (permalink)
Old November 22, 2009, 06:53 PM
AmuseMe's Avatar
Im just lazy/ slow at buying parts. If I had everything I needed since day one, it would have been done by day one (if everything was leak-proof). I mean, I bought everything pretty slowly over the past few months. Liquid Cooling is a never done job
If you get everything in at once, have no "Out of stock" *cough* NCIX, than you can do it all in an afternoon.
  #46 (permalink)
Old November 22, 2009, 10:38 PM
ImmaPC's Avatar
Note to self: Order EVERYTHING you need, All at once, from as few places as possible (preferably only one), one week BEFORE you're gonna build your shit.
Then once you got all your parts together you mount it, plumb it, fill it, run it, check it, fix it, use it, OC it....right? Did I get everything?
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #47 (permalink)
Old November 25, 2009, 07:35 PM
AmuseMe's Avatar
I mean, you do not need to buy everything at once. It might just make you more happy - it definitly would be better for me!
Also, as I learn, a watercooling build never ends. You think you are done, and than "Oh, I want this now, and this, and this. Oh, those look nice!"
  #48 (permalink)
Old November 27, 2009, 07:28 AM
AmuseMe's Avatar
Yay... last of my parts should be coming in by 12:00 noon! (CST/ GMT -6)
Bitspower black sparkle 45's!
  #49 (permalink)
Old November 27, 2009, 08:53 AM
WE DEMAND PICTURES!!... NOW!!... :P
C"mon now, how much patience are you asking from us..
  #50 (permalink)
Old November 27, 2009, 10:21 AM
AmuseMe's Avatar
An on finishing it tonight!
Back to H2o Supergrover Water Cooling 20 August 22, 2009 10:17 AM
[FS] MCP 220 QP RAD CHEAP! Mike_E Buy/Sell & Trade 5 June 30, 2009 06:53 PM
H2O NO! Dr_BenD_over Case Mods, Worklog & Gallery 45 November 23, 2008 10:59 AM
BALISTX - Project Copperhead H2O BALISTX Case Mods, Worklog & Gallery 10 October 11, 2008 04:41 PM
Friendly's Upgrade Project Mr. Friendly Mobile Computing 0 April 16, 2008 12:50 PM
