  #31 (permalink)
Old November 15, 2009, 01:47 PM
ImmaPC's Avatar
Cool, cool. I can't wait to see pics man! What you making me wait so long for? This is gonna be particularly sexy, and like waiting for this is like waiting for your girlfriend to finish deciding a dress for a date or something! XD
And I also can't wait to get my setup going. Waiting for money sucks :p
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #32 (permalink)
Old November 16, 2009, 08:56 AM
That's a lot of expensive hardware, hope all goes well with the build.
Kinda off topic, but the person above me, ImmaPC has a cool username ,hehe.
  #33 (permalink)
Old November 17, 2009, 03:11 PM
AmuseMe's Avatar
Hm... Pic up tonight??? I hope lol... They are all loaded and ready to go, just need to find time to upload them :P
  #34 (permalink)
Old November 18, 2009, 09:14 PM
ImmaPC's Avatar
It's been two days now.... :p
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #35 (permalink)
Old November 19, 2009, 05:54 PM
AmuseMe's Avatar
I know I am late on those pics lol... Should be up tonight!
  #36 (permalink)
Old November 19, 2009, 06:24 PM
ImmaPC's Avatar
I know I'll be waiting
A10-5800K,
F2A85M-PRO
8GB DDR3-2133 CL9
2x XFX 7870
Adata SX900 256GB
Toshiba 1TB
Galaxy 1000W
Antec One
  #37 (permalink)
Old November 19, 2009, 06:46 PM
AmuseMe's Avatar
Imageshack is uploading them as I type! There is nothing to get excited about, just some shots. I also just got my compressions in yesterday!
  #38 (permalink)
Old November 19, 2009, 07:35 PM
AmuseMe's Avatar
I like this pic, took it by accident when the camera was dangling around my neck. Turned out pretty good.
First use of the Compression Fittings. Things to do at this point: Clean the exterior of the radiator.
Note: Use plyers or your finger will be raw, and bleed - for real.
From that 480 Radiator, it comes the Apogee XT, which will be meating some compressions once the 45-degree adapters come in. At the bottom, you see the North Bridge water block, which will have a 45-degree adapter compression corrasponding to one of the CPU ones. Cleans up that big curve!
Things to do at this point: Polish/ Clean the CPU block, and NB.
Next up (from the NB) is the 240 Radiator, which is blowing cool air from the front intake fans of the Antec 1200 into the radiaor, and than into the case following the Radiator fans. Almost like a push-pull.
Note: This radiator will not be seeing compression fitting. I made "dam" sure that the hose clamps are on there, and are "hidden". Those things are not coming off anytime soon!
Next up is the 4870X2, which is being cooled by a Koolance waterblock (or KoolKrap if you prefer). I will be replacing that standard barb with a compression fitting. This is the block that requires barbs with few threads. The BitsPowers ones seems to be short enough, a test will tell in the future.
A messy front shot...
And to end things off (for now) is just a shot of the 480 radiator. Thing is big!
Still need to clean the inside of my case, its been collecting dust for some time now with the pannel off and front intake fans going 24/7 (to dry any distilled water my towel missed). I also plan on giving the whole thing a good cleaning - Interior and Exterior! As well as buffing out any scratches, all of which are hidden/ un-noticed.
  #39 (permalink)
Old November 19, 2009, 10:12 PM
Looking great there.. You're Amusing me for real :p..
Good to see you sort things out and move on to finish this loop, gonna be a killer system.. :)
  #40 (permalink)
Old November 21, 2009, 07:17 PM
AmuseMe's Avatar
I think the greatest thing this thing will see is a dusting rage and some cleaner! It's filthy!
Back to H2o Supergrover Water Cooling 20 August 22, 2009 10:17 AM
[FS] MCP 220 QP RAD CHEAP! Mike_E Buy/Sell & Trade 5 June 30, 2009 06:53 PM
H2O NO! Dr_BenD_over Case Mods, Worklog & Gallery 45 November 23, 2008 10:59 AM
BALISTX - Project Copperhead H2O BALISTX Case Mods, Worklog & Gallery 10 October 11, 2008 04:41 PM
Friendly's Upgrade Project Mr. Friendly Mobile Computing 0 April 16, 2008 12:50 PM
