Old September 30, 2009, 08:25 AM
Default Project: Green Machine
Well, it's about time I get started on this. All my parts are in except for some sleeving which has been ordered. This will be my first time sleeving so bear with me. I'll be starting with my Coolermaster CM690 Nvidia edition which is already stripped down and ready for a light sand and flat black paint. The original green side window will be replaced with clear plexiglass. Many thanks to bojangles for this. Thanks bud! It will be mounted with bolts and acorn nuts.
Name:  DSCF0235 [640x480].JPG
Size:  108.9 KB Name:  DSCF0237 [640x480].JPG
Name:  DSCF0238 [640x480].JPG
Size:  56.7 KB Name:  DSCF0240 [640x480].JPG
Name:  DSCF0253 [640x480].JPG
Size:  44.2 KB Name:  DSCF0261 [640x480].JPG
more to come...
Old September 30, 2009, 09:09 AM
bojangles's Avatar
Haha no problem man. I'm glad you're making a log of this! Didn't wanna see that plastic go to waste lol. Thank god it wasn't scratched. Protective coating can be deceiving :P.
Subscribed!
Old September 30, 2009, 11:18 AM
The side panel is complete. A bandsaw would have come in handy, but your dremel will do in a pinch. A reinforced cutting wheel should be used for this. This was a simple job because I was using my old side panel as a template. All I had to do was trace my pattern to the plexi and cut it out. Please wear eye protection when cutting. This can't be stressed enough.
I found a neat little aid to stick the template and plexi together for drilling the holes for the hardware. They're the little pads you see in the pic and these things work like a charm! They're called poster command strips made by 3M. When your work is done, you simply pull straight on the tab and it will strtch 6"-7" and then pop right out. Ideal for small projects and very inexpensive. Family of Products
Name:  DSCF0264 [640x480].JPG
Size:  51.0 KB Name:  DSCF0265 [640x480].JPG
Name:  DSCF0266 [640x480].JPG
Size:  53.6 KB Name:  DSCF0268 [640x480].JPG
Name:  DSCF0270 [640x480].JPG
more to come...
Old September 30, 2009, 11:56 AM
Are you going to paint the bolts?
Current Rig: C2D E6400 @ 3.0GHz, Vendetta II, BFG 8800 GT, OCZ PC6400 8GB, HX520W, 2x WD 500GB HD, Segate 160GB, WD 200 GB HD, Lancool PC-K62, Windows 7 64 bit, Snow Leopard (on the way)
EVGA 680i SLI Motherboard $80 + Qualitas 73GB 10k SCSI $30
Old September 30, 2009, 12:13 PM
I thought about it, but I'll just take my dremel buffing wheel to them. I wanted a little contrast and give it a slight "machine" look.
Old September 30, 2009, 12:23 PM
sweet....looking good.
Old October 7, 2009, 01:00 AM
Just an update. Due to my rotating shifts and this wet nasty weather we've been having, I haven't been able to get the inside of the case painted yet. I am starting my 5 days off tomorrow and there are a few days that look favorable. I sometimes hate living in an apartment.
I have also noticed that I have a few large scratches on one of my side panels. That means I'm now looking at a complete paint job. As soon as I start sanding the exterior plastic, I'll be comitted. I'll be using an odd paint for the exterior, so I hope I don't it up! I'm going to try to get all the painting done in one day. My sleeving arrived yesterday so I'll start tackling that tomorrow. I'll have more pics up in the next few days.
more to come...
Old October 7, 2009, 05:22 AM
automotive paint!
expensive but sex-looking :]
Primary System:
Pocketbike i7 CaseMod : Intel Core i7 920 @ 4.41 ghz// TRUE120//Asus P6T//eVga nVidia 9800 GTX+//6gb DDR3-1800 OCZ Reapers//Corsair TX750//500gb WD HDD//1TB Samsung HDD
http://www.hardwarecanucks.com/forum...-i7-build.html
Secondary System:
Phenom II 940 @ 3.8ghz//ASUS M4A78-E ATX 790GX//XFX 8800 GTS//OCZ 700W//ThermalTake Soprano RS Modded//8gb OCZ SLI edition DDR2-800//1TB WD Green.
Old October 10, 2009, 07:26 AM
Update:
Painting is in progress and pics will be up this evening. Instead of using flat black for the case interior, I'll be using a satin black. The exterior will be done in a textured metallic charcoal. I hope I don't mess this up.
Old October 10, 2009, 08:26 PM
The painting is now complete. I wish I could have done this inside, but my 23rd floor balcony paint shop had to suffice,lol. At least the weather agreed with me today. The painting turned out better than I had hoped and I'm glad I chose the satin black finish for the case instead of flat black. The textured charcoal metallic also turned out way better than I expected. Btw, the colors you see are actually darker than what is shown here.
I used a spray can handle and I would recommend using one as it will give you way better control over your project. They are stocked at most home improvent stores and for those of you who haven't used one before, it looks like this.
spray can grip Search results | Canadian Tire
Now for some pics. Enjoy!
Size:  71.3 KBName:  DSCF0306 [].JPG
Size:  130.4 KBName:  DSCF0311 [].JPG
Size:  107.3 KBName:  DSCF0314 [].JPG
Size:  155.7 KBName:  DSCF0316 [].JPG
Size:  101.3 KBName:  DSCF0336 [].JPG
Size:  119.1 KBName:  DSCF0344 [].JPG
Size:  99.0 KBName:  DSCF0347 [].JPG
More to come. There is still fan rewiring and some sleeving which I'll be tackling later tonight or tomorrow. Thanks for looking!
Machine burnt out. New machine needed Neutronium New Builds 15 March 18, 2009 12:23 AM
P5Q Deluxe ....Green? Brian CPU's and Motherboards 1 January 23, 2009 12:21 AM
More Green Machine "rumours".. rjbarker Rumor Mill 0 October 12, 2008 06:58 PM
Project "Oscar the Grouch" - the $500 gaming PC project. Jmac Case Mods, Worklog & Gallery 3 January 5, 2008 12:08 AM
Green Border/Color Changes Drader Video Cards 0 October 1, 2007 08:43 PM
